| Author
Matrix Ltd.
| Version
1.2
| Category
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here to download the component source project: FC_Comp_Source_temp/Motor_with_reverse.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Motor_with_reverse.fcfx
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels.
Motors
Break
Break
| Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
Coast
Coast
| Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
Disable
Disable
| Disable the motor output
Enable
Enable
| Enables the motor output
Forwards
Forwards
| Set the motor turning in the forwards direction by setting the pins according to the 'Reverse Pattern' property.
- UINT
Duty
| Sets the motor power for PWM or H-Bridge outputs
Reverse
Reverse
| Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
- UINT
Duty
Control Type
Control Method
| Controls how the motor is controlled. On/Off requires output pins PWM requires a hardware PWM channel H-Bridge requires a hardware H-Bridge channel
Bridge Type
Enable Method
| Decides how the motor outputs are enabled.
PinA
| First control pin - set 'pattern' properties below to set the pin's function.
PinB
| Second control pin - set 'pattern' properties below to set the pin's function.
Forwards Pattern
| The state of pins A and B required to drive the motor in a forwards direction.
Reverse Pattern
| States of pins A and B required to drive the motor in a reverse direction.
Coast Pattern
| States of pins A and B required to stop the motor.
Brake Pattern
Simulation Settings
Speed
| Speed of the motor when turned on. Positive speed -> Counter-clockwsie Negative speed -> Clockwise
Acceleration
| Speed change per second when the motor us powered. Set to zero for instantaneous speed changes.
Deceleration
| Speed change per second when the motor is coasting with no power. Set to zero for instantaneous speed changes.
Show Actuator
| When active, an actuator is shown on the motor spindle to make the animation easier to observe.
Forwards Direction
| Which way the motor will rotate when the 'forwards' command is sent.
Linkage
Target Object
| An object or group to link the motor to - the object will move along with the motor.
