Component: Robot Arm v2 (AllCode)
| Category | AllCode |
- 1 Robot Arm v2 component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 DisableMotors
- 5.2 GetAPI
- 5.3 GetAngles
- 5.4 GetColourSensor
- 5.5 GetPLCInputs
- 5.6 GetPosition
- 5.7 GetWifiIP
- 5.8 GetXYZ
- 5.9 GotoPosition
- 5.10 HomeAll
- 5.11 HomeAxis
- 5.12 Initialise
- 5.13 IsMoving
- 5.14 ResetToBoot
- 5.15 SetAngle
- 5.16 SetAngles
- 5.17 SetBluetoothMode
- 5.18 SetBluetoothName
- 5.19 SetBluetoothPin
- 5.20 SetCalibrationLengths
- 5.21 SetCalibrationPosition
- 5.22 SetCalibrationRadius
- 5.23 SetCanId
- 5.24 SetCanMode
- 5.25 SetGripper
- 5.26 SetMotor
- 5.27 SetMotors
- 5.28 SetMovementSpeed
- 5.29 SetRelay
- 5.30 SetWIFIPassword
- 5.31 SetWIFIPort
- 5.32 SetWifiMode
- 5.33 SetWifiSSID
- 5.34 SetXYZ
- 5.35 StoreAngles
- 5.36 StoreCurrentPosition
- 5.37 StoreMotors
- 5.38 WhileMoving
- 6 Property reference
Drives the Matrix Robot Arm v2 hardware via the AllCode API. Allows connections via USB, Bluetooth and WIFI.
Please click here to download the component source project: FC_Comp_Source_temp/RA2_ComponentSource.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/RA2_ComponentSource.fcsx
DisableMotors
| DisableMotors | |
| Disables all motors | |
GetAPI
| GetAPI | |
| Gets the API version number | |
GetAngles
| GetAngles | |
| Collects the current joint angles of the motors. | |
| Angles | |
| Float Array To Hold the step position return values | |
GetColourSensor
| GetColourSensor | |
| Samples and returns the RGB values read by the colour sensor | |
| RGB | |
| Byte Array To Hold the RGB sensor values | |
GetPLCInputs
| GetPLCInputs | |
| Reads the inputs on the secondary grove connector used to connect to outputs from a connected PLC or other external switch. | |
GetPosition
| GetPosition | |
| Collects the current step positions of the motors. | |
| Positions | |
| UINT Array To Hold the step position return values | |
GetWifiIP
| GetWifiIP | |
| Collects the IP address of the robot arm WIFI connection. | |
GetXYZ
| GetXYZ | |
| Collects the current XYZ position of the end tool. | |
| XYZ | |
| INT Array To Hold the X, Y and Z return values | |
GotoPosition
HomeAll
| HomeAll | |
| Function to automatically home all motors. Macro blocks until complete. | |
HomeAxis
| HomeAxis | |
| Function to automatically home a specific motor. Macro blocks until complete. | |
| Axis | |
| 0=A, 1=B, 2=C | |
IsMoving
| IsMoving | |
| Checks to see if the robot arm or gripper is moving. Returns 0 if the arm is not moving and 1 if the arm is still in transit. | |
ResetToBoot
| ResetToBoot | |
| Resets the board into bootload mode for reprogramming. Comms port will be closed on calling this macro, | |
SetAngle
| SetAngle | |
| Sets the angle of a single motor | |
| Motor | |
| 0=A, 1=B, 2=C | |
| Angle | |
| Range 0.0 to 359.0 | |
SetAngles
| SetAngles | |
| Sets the angle of all motors | |
| AngleA | |
| AngleB | |
| AngleC | |
SetBluetoothMode
| SetBluetoothMode | |
| Configures the Bluetooth mode. | |
| Mode | |
| 0=Disabled, 1=Enabled | |
SetBluetoothName
SetBluetoothPin
| SetCalibrationLengths | |
| Sets the lengths of parameters A and D used as part of the kinematics calculations to get and set the angles using XYZ coordinates | |
| LengthA | |
| LengthD | |
| SetCalibrationRadius | |
| Radius | |
SetCanId
| SetCanId | |
| Stores the specified CAN ID into an internal none volatile memory location. | |
| ID | |
SetCanMode
| SetCanMode | |
| Configures the CAN mode. | |
| Mode | |
SetGripper
| SetGripper | |
| Sets the new position of the gripper | |
| Position | |
| 0 = Closed, 255 = Fully Open | |
SetMotor
| SetMotor | |
| Sets the step position of a single motor | |
| Motor | |
| 0=A, 1=B, 2=C | |
| Position | |
SetMotors
| SetMotors | |
| Sets the step position of all motors | |
| PositionA | |
| PositionB | |
| PositionC | |
SetMovementSpeed
| SetMovementSpeed | |
| Controls the movement speed of the arm and the ramping increment | |
| Speed | |
| Range 0-10000 default 8000 | |
| Increment | |
| Range 0 to 5000, default 50 | |
SetRelay
| SetRelay | |
| Allows the vacuum relay to be switched on and off. | |
| State | |
SetWIFIPassword
SetWIFIPort
| SetWIFIPort | |
| Sets the WIFI port number | |
| Port | |
| Default 1245 | |
SetWifiMode
SetWifiSSID
SetXYZ
| SetXYZ | |
| Moves the machine so that the end tool is in the specified XYZ position. Returns 1 if the coordinates are within range of the Arm else returns 0. | |
| X | |
| Y | |
| Z | |
StoreAngles
| StoreCurrentPosition | |
| Stores the current position into an internal none volatile memory location. | |
| PositionIndex | |
| Range: 0 to 40 | |
StoreMotors
| StoreMotors | |
| Stores the specified step position into an internal none volatile memory location. | |
| PositionIndex | |
| Range: 0 to 40 | |
| PositionA | |
| PositionB | |
| PositionC | |
WhileMoving
