Component: Range Time of Flight (VL53L0X) (Light)
Jump to navigationJump to search| Author | MatrixTSL |
| Category | Light |
Range Time of Flight (VL53L0X) component
A laser based range sensor designed to provide accurate range infomation for a very narrow sensing beam. Capable of sensing ranges from 50mm to 1200mm. Communication with the device is based on a I2C bus.
Please click here to download the component source project: FC_Comp_Source_temp/RangeTOF_VL53L0X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/RangeTOF_VL53L0X.fcfx
Simple example showing the proximity detector component at work, when a proximity is detected the direction of the motor is reversed.
Detector
ReadDistance
| ReadDistance | |
| Read the current distance in mm. Returns -1 if the sensor timed out during the read operation. | |
ReadModel
| ReadModel | |
| Collects the model number from the sensor | |
ReadRevision
| ReadRevision | |
| Collects the revision number from the sensor | |
