Component: Servo Motor (Standard) ()
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
Servo Motor (Standard) component
Standard size servo motor suitable for control by the 'Servo Controller' component. Use the 'Link to...' property to attach other objects to the rotor for emulating mechanical systems. Send a virtual PWM signal to the servo by selecting it as a target of the 'Servo Controller' component.
Please click here to download the component source project: FC_Comp_Source_temp/Standard_Servo.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Standard_Servo.fcfx
A simple example that shows how to use some common functions to control a servo.
Controlling Servos Example
Link To...
Select a panel object here to connect it 'mechanically' to the servo's actuator. The selected object will now be moved whenever the servo position changes. NB) To move multiple objects, first group the objects, and then select the group.
Reverse Output
Some manufacturers motors may rotate in different ways to others. Changing this property allows you to flip the direction of the simulated motor to better match with the real world hardware.
Movement Type
