Component: TCP/IP (ENC28J60) (Comms: Networking)
Version | 2.2 |
Category | Comms: Networking |
- 1 TCP/IP (ENC28J60) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 CheckArpPacketIsMyreplyArp
- 5.2 CheckForARP
- 5.3 CheckForIp
- 5.4 CheckForPing
- 5.5 CheckForTCPPort
- 5.6 CheckForTCPType
- 5.7 ClientSendPacket
- 5.8 ControlLEDs
- 5.9 FillTcpArray
- 5.10 FillTcpData
- 5.11 GetDataLength
- 5.12 GetModuleRevision
- 5.13 GetSendersMAC
- 5.14 GetTcpDataPointer
- 5.15 Initialise
- 5.16 InitialiseDataLengthInfo
- 5.17 MakeArpAnswerFromRequest
- 5.18 MakeArpRequest
- 5.19 MakeEchoReplyFromRequest
- 5.20 MakeTcpAckFromAny
- 5.21 MakeTcpAckWithData
- 5.22 MakeTcpSynackFromSyn
- 5.23 PacketReceive
- 5.24 PacketSend
- 5.25 ReadArrayFromBuffer
- 5.26 ReadRegister
- 5.27 ReadStringFromBuffer
- 5.28 SetMyIPAddress
- 5.29 SetMyMACAddress
- 5.30 WriteRegister
- 6 Property reference
A set of routines used to control a ENC28J60 TCP/IP Module. Required connections VCC, Reset, GND, SCK, MISO, MOSI, CS. Leave these pins disconnected CLKOUT, ENC_WOL, ENC_INT
Please click here to download the component source project: FC_Comp_Source_temp/TCPIP_ENC28J60.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/TCPIP_ENC28J60.fcfx
CheckArpPacketIsMyreplyArp |
Return |
CheckForARP
CheckForARP |
Checks to see if the received data is an ARP request with my IP address. | |
Length |
Return |
CheckForIp
CheckForIp |
Checks to see if the received data is an IP request with my IP address. | |
Length |
Return |
CheckForPing
CheckForPing |
Checks to see if the received data is a Ping request | |
Return |
CheckForTCPPort
CheckForTCPPort |
Checks to see if the received data is requesting the server port | |
Port |
Return |
CheckForTCPType
CheckForTCPType |
Checks to what kind of TCP type the received data is requesting. Returns a bit field specifying the type of request. 0x01 = Ack Requires, 0x02 = Synchronise 0x10 = Ack | |
Return |
ClientSendPacket
ClientSendPacket |
DestPort |
SourcePort |
Flags |
MaxSegmentSize |
ClearSeqAck |
NextAckNum |
DataLength |
DestMac |
DestIp |
Return |
ControlLEDs
ControlLEDs |
Allows both the LEDs on the Ethernet socket to be controlled. Useful for checking if the SPI communications are functioning correctly. | |
Mode |
0=Off, 1=On, 2=Auto | |
Return |
FillTcpArray
FillTcpArray |
Position |
Count |
Data |
Return |
FillTcpData
FillTcpData |
Position |
Data |
Return |
GetDataLength
GetDataLength |
Returns the number of received data bytes after the headers | |
Return |
GetModuleRevision
GetModuleRevision |
Requets the module revision number and returns the value supplied by the module's firmware. | |
Return |
GetSendersMAC
GetSendersMAC |
Gets the MAC address from locations 6-11 of the IP Header | |
MAC |
6-byte Array to store the MAC address | |
Return |
GetTcpDataPointer
GetTcpDataPointer |
Return |
InitialiseDataLengthInfo |
Initialises the data pointers to allow us to craft a response containing data | |
Return |
MakeArpAnswerFromRequest |
Return |
MakeArpRequest
MakeArpRequest |
[[File:]] - | ServerIP |
Return |
MakeEchoReplyFromRequest |
Length |
Return |
MakeTcpAckFromAny
MakeTcpAckFromAny |
Port |
Return |
MakeTcpAckWithData
MakeTcpAckWithData |
DataLength |
Return |
MakeTcpSynackFromSyn |
Port |
Return |
PacketReceive
PacketReceive |
Attempts to receive a data packet from the ENC28J60 module. Returns the number of bytes received. | |
Return |
PacketSend
PacketSend |
Attempts to transmit a data packet to the ENC28J60 module. | |
Length |
Return |
ReadArrayFromBuffer
ReadRegister
ReadRegister |
Reads the value from a single register onboard the ENC28J60 module. | |
Address |
Return |
SetMyIPAddress
SetMyMACAddress
WriteRegister
WriteRegister |
Writes a value to a single register onboard the ENC28J60 module. | |
Address |
Data |
Return |
