Component: Webserver (WIZ810MJ) (Comms: Networking)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 2.0 |
| Category | Comms: Networking |
- 1 Webserver (WIZ810MJ) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 CheckSocketActivity
- 5.2 CreateServerSocket
- 5.3 GetInValue
- 5.4 IncRxPtr
- 5.5 Initialise
- 5.6 MIAC_Module_GetData
- 5.7 MIAC_Module_Message
- 5.8 MIAC_Module_PushData
- 5.9 MIAC_Module_SetData
- 5.10 Send_Embedded_HTML_Page1
- 5.11 Send_Embedded_HTML_Page2
- 5.12 Send_Embedded_HTML_Page3
- 5.13 Send_Embedded_HTML_Page4
- 5.14 SetOutValue
- 5.15 WM_CH_CR
- 5.16 WM_CH_IR
- 5.17 WM_CH_MR
- 5.18 WM_CH_PORT
- 5.19 WM_CH_RX_RSR
- 5.20 WM_CH_SR
- 5.21 WM_CH_TX_WR
- 5.22 WM_RXMEM
- 5.23 WM_TXMEM
- 6 Property reference
Webserver component designed to work with the WIZ810MJ module from Wiznet, as used in the version 2 EB023 E-block and MIAC System Industrial Addon. Provides a very simple interface to allow webpages to be hosted from hardware or simulation.
Please click here to download the component source project: FC_Comp_Source_temp/WebServer_WIZ810MJ.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/WebServer_WIZ810MJ.fcfx
CheckSocketActivity
|   | CheckSocketActivity |
| Checks for activity on the server socket and serves out the webpages to any requesting parties. | |
|  - BYTE | Return |
CreateServerSocket
|   | CreateServerSocket |
| Creates a listening socket on the selected channel and port ready to accept incoming web page requests. | |
|  - BYTE | Channel |
|  - UINT | Port |
|  - BYTE | Return |
GetInValue
|   | GetInValue |
| Returns the string value of a Request parameter | |
|  - BYTE | index |
|  - STRING | Return |
IncRxPtr
|   | IncRxPtr |
|  - BYTE | Channel |
|  - VOID | Return |
MIAC_Module_GetData
|   | MIAC_Module_GetData |
|  - BYTE | Index |
|  - BYTE | Return |
MIAC_Module_Message
|   | MIAC_Module_Message |
|  - UINT | CAN_ID |
|  - UINT | CMD_ID |
|  - BYTE | Return |
|   | MIAC_Module_PushData |
|  - BYTE | Data |
|  - VOID | Return |
MIAC_Module_SetData
|   | MIAC_Module_SetData |
|  - BYTE | Count |
|  - BYTE | D0 |
|  - BYTE | D1 |
|  - BYTE | D2 |
|  - BYTE | D3 |
|  - BYTE | D4 |
|  - BYTE | D5 |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page1 |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page2 |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page3 |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page4 |
|  - VOID | Return |
SetOutValue
|   | SetOutValue |
| Set the value of an outbound substitution string | |
|  - BYTE | index |
|  - STRING | value |
|  - VOID | Return |
WM_CH_CR
|   | WM_CH_CR |
|  - BYTE | ch |
|  - UINT | Return |
WM_CH_IR
|   | WM_CH_IR |
|  - BYTE | ch |
|  - UINT | Return |
WM_CH_MR
|   | WM_CH_MR |
|  - BYTE | ch |
|  - UINT | Return |
WM_CH_PORT
|   | WM_CH_PORT |
|  - BYTE | ch |
|  - UINT | Return |
WM_CH_RX_RSR
|   | WM_CH_RX_RSR |
|  - BYTE | ch |
|  - UINT | Return |
WM_CH_SR
|   | WM_CH_SR |
|  - BYTE | ch |
|  - UINT | Return |
WM_CH_TX_WR
|   | WM_CH_TX_WR |
|  - BYTE | ch |
|  - UINT | Return |
WM_RXMEM
|   | WM_RXMEM |
|  - BYTE | ch |
|  - UINT | Return |
WM_TXMEM
|   | WM_TXMEM |
|  - BYTE | ch |
|  - UINT | Return |
