Component: Wii Nunchuk (Movement Orientation)
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Movement Orientation
Wii Nunchuk component
A component to interface the Wii Nunchuck which features a 3-axis 10-bit Accelerometer A 2-axis 8-bit joystick and two digital button inputs. Interfaced using a standard I2C bus at 100KHz. Nunchuk must be powered at 3V3 to avoid damage.
Please click here to download the component source project: FC_Comp_Source_temp/WiiNunchuck.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/WiiNunchuck.fcfx
Fc9-comp-macro.png Initialise
Sets up up the communication bus and initialises the accelerometer module. Returns 1 for success and 0 for fail.
ReadAccelerometer
Fc9-comp-macro.png ReadAccelerometer
Reads a single Accelerometer axis
Fc9-u8-icon.png - BYTE Axis
0=X, 1=Y, 2=Z
Fc9-s16-icon.png - INT Return
ReadJoystick
Fc9-comp-macro.png ReadJoystick
Reads a single joystick axis
0=X, 1=Y
ReadSwitch
Fc9-comp-macro.png ReadSwitch
Reads one of the nunchuck switches
Fc9-u8-icon.png - BYTE Switch
0=Z, 1=C
Sample
Fc9-comp-macro.png Sample
Reads from the nunchuck and updates the local variables.
SimReset1G
Fc9-comp-macro.png SimReset1G
Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
The number of binary bits used to store the sensor's X,Y,Z readings.
Fc9-type-7-icon.png Encryption
Decides if encryption should be active or disabled
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - API etc
