| Author
Matrix Ltd.
| Version
1.2
| Category
Misc
Component Label component
Add a label to a component by including this component as a sub-component. The label will always face the viewer and move with its parent object. Text for the label is automatically read from the host component's name or any chosen property.
Please click here to download the component source project: FC_Comp_Source_temp/component_label.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/component_label.fcfx
Hide
Hide
| Hides the label.
SetColor
SetColor
| Sets the color of the label using a single ULONG value - such as returned by panel GetColor functions.
- ULONG
Color
| Color to set the labels to.
SetColorRGB
SetColorRGB
| Set the label color using separate red, green and blue color channels.
- BYTE
Red
| Color parameter
- BYTE
Green
| Color parameter
- BYTE
Blue
| Color parameter
SetPosition
SetPosition
| Set where the label will appear relative to the object.
- BYTE
Position
| Set the position - choose a preset from the list of constants, or 'Position XYZ to enter values below.
- FLOAT
X
| X axis offset (only if 'Position_XYZ' selected for 'Position')
- FLOAT
Y
| Y axis offset (only if 'Position_XYZ' selected for 'Position')
- FLOAT
Z
| Z axis offset (only if 'Position_XYZ' selected for 'Position')
SetTargets
SetTargets
| Set the objects used to determine the label text and position.
- HANDLE
TextObject
| Object that will provide the label text from its name or a property.
- HANDLE
BoundsObject
| Object that will set the label position and bounding box.
ShowName
ShowName
| Sets the label to show the target object's name
ShowProperty
ShowProperty
| Sets the label to show a named property of the target object.
- STRING
Property
| Name of the property to show.
Update
Update
| Refresh the label after a change.
Show
| Decide what label to show... None - no labels are displayed Name - shows the component's name Property - shows a property value of the component (a field for the property name will appear below)
Label target
| Set the object from which the label text will be taken. If none is given, defaults to the parent of the label component.
Bounds target
| Set the object used to set the dimensions used for the positioning of the labels. If none is given, defaults to the parent of the label component.
Auto Update
| Automatically update the label whenever the target's name or labelled property changes. Use this sparingly, as it requires the component to regularly poll the component for changes!!
Color
| Color of the label text.
Background
| Color for label backgroiunds - may be transparent.
Always On Top
| Whether labels should always be draw on top of other objects.
Size
Scale
| Sets the basic size (text height) of the labels.
Follow Zoom
| Whether labels get bigger and smaller when the panel is zoomed in and out.
Offset
Auto
| Attempt to automatically move the label to the side of the object. Choose a positive or negative offset in any of the three axes. When 'off', the manual offsett values can be edited below.
