Component: Dial control (Misc)
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Author
Version 1.1
Category Misc
Dial control component
Dial output control
Please click here to download the component source project: FC_Comp_Source_temp/dial.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/dial.fcfx
GetPos
Fc9-comp-macro.png GetPos
Gets the position of the pointer
SetAngles
Fc9-comp-macro.png SetAngles
Sets the min-max angles to draw on the dial Used for setting the needle Defaults are 135 and -45
Fc9-s16-icon.png - INT Start
Fc9-s16-icon.png - INT End
SetLabel
Fc9-comp-macro.png SetLabel
Sets the label to draw in the center of the dial
Fc9-string-icon.png - STRING Hi
Fc9-string-icon.png - STRING Lo
Label to draw at the bottom
SetMarks
Fc9-comp-macro.png SetMarks
Decides on the presentation of the dial
Fc9-s16-icon.png - INT Marks
Number of marks on the dial
Fc9-s16-icon.png - INT Subs
Number of marks before a 'main' mark - can be zero
Fc9-bool-icon.png - BOOL ShowNumbers
True to show numbers on the dial, else false
SetPos
Fc9-comp-macro.png SetPos
Sets the position of the dial, bounded to the pre-set range
Fc9-f32-icon.png - FLOAT Position
The position of the dial in the Users specified range
Fc9-bool-icon.png - BOOL Notify
Set to true to notify owner Target of a change
SetRange
Fc9-comp-macro.png SetRange
Sets the min-max range to draw on the dial Used for setting the needle
SetTarget
Fc9-comp-macro.png SetTarget
Sets the target of change messages Send 0 as the target ID to disable
Fc9-h32-icon.png - HANDLE Target
The target component to recieve the message
Fc9-u32-icon.png - ULONG MessageId
The identifier of the message to send to
