Component: Switch (Push, PCB) ()
Revision as of 12:04, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
Switch (Push, PCB) component
Simple tactile PCB switch for PCB mounting. Approx. 12 * 12mm. Color and operation can be set from properties.
Please click here to download the component source project: FC_Comp_Source_temp/sw_push_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/sw_push_pcb.fcfx
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
Connection
The chip pin to which the switch connects.
Polarity
Set the polarity of states sent to the chip pin. 'Active High' -> Pressed = On, Released = Off 'Active Low' -> Pressed = Off, Released = On
Debounce (ms)
Sets the time in milliseconds to allow a pin change to settle into a stable state. NB) Debouncing is only used when reading the button state using the component macros. Chip pins are NOT debounced.
Operation
Latching = Mouse click to turn on, click again to trun off. Momentary = Click to turn on, release to turn off.
Color
Color of the key cap
