Component: DAC (MCP48x1) (MCP48x1) (Analog Output)
Version | 1.0 |
Category | Analog Output |
DAC (MCP48x1) component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4801 (8-Bit), MCP4811 (10-Bit) and MCP4821 (12-Bit) devices.
Please click here to download the component source project: FC_Comp_Source_temp/DAC_MCP48x1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DAC_MCP48x1.fcfx
ControlPins
Disable
Disable |
Disables the DAC output. | |
Return |
Enable
Enable |
Enables the DAC Output. | |
Return |
Initialise |
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated. | |
Return |
SetOutput
SetOutput |
Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095 | |
DAC_Value |
The value to output to the DAC | |
Return |
