Component: Humidity (EBM016) (EBM Modules)
| Version | 2.0 |
| Category | EBM Modules |
Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the Matrix e-block module EBM016. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Please click here to download the component source project: FC_Comp_Source_temp/EBM016v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EBM016v1.fcfx
This example reads the temperature and humidity levels from the sensor and displays the readings on the LCD.
GetHumidityData
| GetHumidityData | |
| Returns the raw register pair value | |
GetHumidityInt
| GetHumidityInt | |
| returns the relative Humidity reading as an integer value | |
GetHumidityReal
| GetHumidityReal | |
| returns the Humidity reading as a float value | |
GetTemperatureData
| GetTemperatureData | |
GetTemperatureInt
| GetTemperatureInt | |
| Return temperature reading as an integer value in degrees C | |
GetTemperatureReal
| GetTemperatureReal | |
| Return temperature reading as a float value in degrees C | |
| Initialises the component ready for I2C communications | |
