Component: Infrared (EBM020) (EBM Modules)
Revision as of 12:19, 3 February 2023 by Wiki bot (talk | contribs)
Category EBM Modules
Infrared component
The Infrared sensor board contains both an IR transmitter and receiver. The transmitter is enabled via a digital control signal and the receiver provides an analogue output. By enabling the transmitter and reading the variable voltage output of the receiver it is possible to measure the distance of a reflecting object in the region of 1cm to 10cm.
Please click here to download the component source project: FC_Comp_Source_temp/EBM020v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EBM020v1.fcfx
GetADCValue
GetADCValue
Gets the raw ADC input value for the IR receiver
GetDistanceValue
GetDistanceValue
Returns the calculated distance for the given ADC reading
- BYTE adc
Initialise the component by loading the default calibration table
SetTxOff
SetTxOff
Turns off the IR Transmitter
SetTxOn
SetTxOn
Turns on the IR Transmitter
Input ADC Channel
Analog input channel for the IR receiver
Output Enable Pin
Pin used to control the IR Transmitter
Initial/ Hardware Calibration Table
Point 1 ADC Value
The ADC value that would give the Point 1 Distance. If the ADC value is 0 the point is ignored.
Point 1 Distance (mm)
The distance returned for an ADC reading given by Point 1 ADC value
Point 2 ADC Value
Point 2 Distance (mm)
Point 3 ADC Value
Point 3 Distance (mm)
Point 4 ADC Value
Point 4 Distance (mm)
