Component: Formula AllCode API (AllCode)
Revision as of 12:19, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category AllCode
Formula AllCode API component
A simulation only component to allow the Formula AllCode robot to be controlled via it's API interface and Bluetooth data connection without having to compile or re-program the robot.
Please click here to download the component source project: FC_Comp_Source_temp/FormulaAllCode_API.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/FormulaAllCode_API.fcsx
The COM port for the Formula AllCode can be set via the panel properties which can be exposed to the SCADA runtime user.
LED Control
Controls the LEDs on the Formula AllCode by collecting the analogue value of a potentiometer on the simulation panel and sending the value to the robot.
FC6 Icon.png LED Control Example
Motor Control Using Keypad
Uses the keypad on the simulation panel to control the speed and direction of the motors. Key 2 drives the robot forwards, 8 drives backwards, 4 and 6 turn the robot on the spot.
FC6 Icon.png Motor Control Example
Motor Control Using Joystick
A simple example showing how to drive the Formula AllCode robot around in API mode using a panel based joystick control.
FC6 Icon.png Formula AllCode Bluetooth
Proximity Alarm
Reads the front IR sensor on the Formula AllCode from the Flowcode simulation. If a near object is sensed then the Flowcode simulation will speak the word "Hello" using the Speech component.
FC6 Icon.png Proximity Alarm Example
Driving Simulation using the API component
An example showing how to use the API component to drive the Formula AllCode robot component on the simulation panel.
FC6 Icon.png FA API Sim Demo
JCB Bot Blog
Blog with example code showing how to drive the Formula AllCode robot using Key Mappings and how to add extra features such as a 3D printed cover and servo motors to operate a digger arm and bucket.
JCB Bot
Backwards
Fc9-comp-macro.png Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
Fc9-u16-icon.png - UINT Distance
Distance in mm
CardBitmap
Fc9-comp-macro.png CardBitmap
Displays a monochrome bitmap read from the card on the LCD
Fc9-u8-icon.png - BYTE X
Range 0-127
Fc9-u8-icon.png - BYTE Y
Range 0-31
CardCreate
Fc9-comp-macro.png CardCreate
Attempts to create a file on the SD card 255=Error, 1=File Already Exists, 0=Create OK
CardErase
Fc9-comp-macro.png CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
CardInit
Fc9-comp-macro.png CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
CardOpen
Fc9-comp-macro.png CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
CardPlayback
Fc9-comp-macro.png CardPlayback
Plays back a .Wav file audio stream from the card
CardReadByte
Fc9-comp-macro.png CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
CardRecordMic
Fc9-comp-macro.png CardRecordMic
Records an audio stream on the card from the microphone
Fc9-u8-icon.png - BYTE BitDepth
0=8-bit, 1=16-bit
Fc9-u8-icon.png - BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
Fc9-u16-icon.png - UINT RecordTime
Time to record for in seconds, Range 0-65535
CardWriteByte
Fc9-comp-macro.png CardWriteByte
Appends a byte to the end of the currently open file
Fc9-u8-icon.png - BYTE Data
EncoderRead
Fc9-comp-macro.png EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
Fc9-u8-icon.png - BYTE index
0=Left, 1=Right
EncoderReset
Fc9-comp-macro.png EncoderReset
Resets the motor encoder counters
Forwards
Fc9-comp-macro.png Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
Distance in mm
GetConsoleHandle
GetProp
Fc9-comp-macro.png GetProp
Allows the property filter for the COM port list to be copied to a parent component.
Fc9-string-icon.png - STRING PropName
LCDBacklight
Fc9-comp-macro.png LCDBacklight
Allows the LCD backlight brighntess to be adjusted
Fc9-u8-icon.png - BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
LCDClear
Fc9-comp-macro.png LCDClear
Clears the LCD
LCDDrawLine
Fc9-comp-macro.png LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
Fc9-u8-icon.png - BYTE X1
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y1
Y Pixel 0-31
Fc9-u8-icon.png - BYTE X2
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y2
Y Pixel 0-31
LCDDrawPixel
Fc9-comp-macro.png LCDDrawPixel
Allows a single pixel on the LCD to be set or cleared
X Pixel 0-127
Y Pixel 0-31
Fc9-u8-icon.png - BYTE State
0=White (Off), 1=Black (On)
LCDDrawRect
Fc9-comp-macro.png LCDDrawRect
Allows a rectangle to be drawn on the LCD
X Pixel 0-127
Y Pixel 0-31
X Pixel 0-127
Y Pixel 0-31
LCDPrintNumber
Fc9-comp-macro.png LCDPrintNumber
Prints a 16-bit signed number to the LCD
X Pixel 0-127
LCD Y coordinate 0-31
Fc9-s16-icon.png - INT Number
Range -32768 to 32767
LCDPrintString
Fc9-comp-macro.png LCDPrintString
Prints a string to the LCD
X Pixel 0-127
LCD Y Coordinate 0-31
LCDVerbose
Fc9-comp-macro.png LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
0=Off 1=On
LEDOff
Fc9-comp-macro.png LEDOff
Clears a single LED 0-7
Range: 0-7
LEDOn
Fc9-comp-macro.png LEDOn
Sets a single LED 0-7
Range: 0-7
LEDWrite
Fc9-comp-macro.png LEDWrite
Sets the value of the LEDs as an 8-bit output
Fc9-u8-icon.png - BYTE Value
LED value 0=All Off, 255 = All On
Left
Fc9-comp-macro.png Left
Rotates the robot left - waits for the angle to be traversed before returning
Fc9-u16-icon.png - UINT Angle
Angle to turn in degrees
PlayNote
Fc9-comp-macro.png PlayNote
Plays a note using the speaker on the FA
Fc9-u16-icon.png - UINT Note
Range 1 to 65535 in Hz
Fc9-u16-icon.png - UINT Delay
Number of milliseconds to play the note for
ReadAllSensors
Fc9-comp-macro.png ReadAllSensors
Samples all of the robot's sensors at once, storing the values locally
ReadAllValue
Fc9-comp-macro.png ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
Fc9-u8-icon.png - BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
ReadAxis
Fc9-comp-macro.png ReadAxis
Reads a single X/Y/Z axis from the accelerometer sensor.
0=X, 1=Y, 2=Z
Fc9-s16-icon.png - INT Return
ReadBearing
Fc9-comp-macro.png ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
ReadIR
Fc9-comp-macro.png ReadIR
Reads an IR sensor 0=Left, 1=FrontLeft, 2=Front, 3=FrontRight, 4=Right, 5=RearRight, 6=Rear, 7=RearLeft
ReadLight
Fc9-comp-macro.png ReadLight
Reads the light sensor 0-4095 - 4095 = Max Brightness
ReadLine
Fc9-comp-macro.png ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
0=Left, 1=Right
ReadMic
Fc9-comp-macro.png ReadMic
Reads the microphone sensor 0 - 4095
ReadSwitch
Fc9-comp-macro.png ReadSwitch
Read the switch value
0 (left) or 1 (right)
Right
Fc9-comp-macro.png Right
Rotates the robot right - waits for the angle to be traversed before returning
SampleAccel
Fc9-comp-macro.png SampleAccel
Samples the accelerometer 0 = no new data, 1 = new data available
SampleMag
Fc9-comp-macro.png SampleMag
Samples the magnetometer 0 = no new data, 1 = new data available
ServoAutoMoveToPosition
Fc9-comp-macro.png ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
Range 0-3
Fc9-u8-icon.png - BYTE Position
Range 0-255
ServoDisable
Fc9-comp-macro.png ServoDisable
Allows one of the servo outputs 0-3 to be disabled
Range 0-3
ServoEnable
Fc9-comp-macro.png ServoEnable
Allows one of the servo outputs 0-3 to be enabled
Range 0-3
ServoSetAutoMoveSpeed
Fc9-comp-macro.png ServoSetAutoMoveSpeed
Changes the speed of the auto movements Default - 1
Fc9-u8-icon.png - BYTE Speed
Range 1-50
ServoSetPosition
Fc9-comp-macro.png ServoSetPosition
Allows one of the servo positions to be assigned
Range 0-3
Range 0-255
SetLogoSpeed
Fc9-comp-macro.png SetLogoSpeed
Sets the speed of logo movements
Logo Speed 1-100 - Default 40
SetMotors
Fc9-comp-macro.png SetMotors
Sets the motor speeds without feedback Range -100 to 100
Fc9-s16-icon.png - INT Left
Range -100 to 100
Fc9-s16-icon.png - INT Right
Range -100 to 100
SetProp
Fc9-comp-macro.png SetProp
Allows the COM port property to be set from a parent component.
Fc9-u32-icon.png - ULONG PropVal
Fc9-type-16-icon.png COM Port
Selects which port to communicate with, only lists ports which are currently available.
Fc9-type-7-icon.png Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Fc9-type-14-icon.png Baud
Baud rate passed to the COM port to control the rate of data.
Fc9-type-10-icon.png Label
