Component: Keypad (Numeric 3x4) (Keypad)
Revision as of 12:20, 3 February 2023 by Wiki bot (talk | contribs)
Category Keypad
Keypad (Numeric 3x4) component
Preset keypad based around the 3 * 4 unit, as used by the Matrix EB014 E-block
Please click here to download the component source project: FC_Comp_Source_temp/Keypad_Numeric.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Keypad_Numeric.fcfx
Basic Example
Keypad Example File demonstrating controlling a door lock.
LED is used to show the pin status controlling the door lock.
Keypad Door Entry
GetAscii
GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
GetIndex
GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
GetNumber
GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
GetString
GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string.
- STRING Return
WaitPressed
WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
WaitReleased
WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Port
From here, set the port to which your EB014 is connected. If you are wiring your own hardware, you can use the 'Custom Pins' setting to allow the selection of individual pins for each row or column.
