Component: LCD (Adafruit, 20x4) (Alphanumeric)
Revision as of 12:20, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.10
Category Alphanumeric
LCD (Adafruit, 20x4) component
Adafruit OLED LCD display capable of displaying 4 lines of 20 characters.
Please click here to download the component source project: FC_Comp_Source_temp/LCD_Adafruit_OLED2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LCD_Adafruit_OLED2.fcfx
Clear
Fc9-comp-macro.png Clear
ClearLine
Fc9-comp-macro.png ClearLine
Clears a single line on the display before moving the cursor back to the start of the line to allow new data to be displayed.
Fc9-u8-icon.png - BYTE Line
Command
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Cursor
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Fc9-u8-icon.png - BYTE y
PrintAscii
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Holds an ascii value.
PrintFloat
Fc9-comp-macro.png PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
PrintFormattedNumber
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
PrintString
Fc9-comp-macro.png PrintString
RAMWrite
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Values 0 to 7
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
RemapCharacter
Fc9-comp-macro.png RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
Fc9-u8-icon.png - BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
Fc9-u8-icon.png - BYTE SearchCharacter
Character to look for a replace
Fc9-u8-icon.png - BYTE ReplacementCharacter
New character value to use in place of the search character.
ScrollDisplay
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE Position
Holds the number of positions to shift the display
Fc9-u8-icon.png - BYTE direction
0 = left, 1 = right
Start
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display when complete.
Fc9-type-5-icon.png Data 0 (11)
Data pin 0 connects to data pin 4 on the hardware
Fc9-type-5-icon.png Data 1 (12)
Data pin 1 connects to data pin 5 on the hardware
Fc9-type-5-icon.png Data 2 (13)
Data pin 2 connects to data pin 6 on the hardware
Fc9-type-5-icon.png Data 3 (14)
Data pin 3 connects to data pin 7 on the hardware
Fc9-type-5-icon.png Register Select (4)
Register select pin, determines if the incoming value is a command or a data byte
Fc9-type-5-icon.png Read / Write (5)
Read / Write pin determines the data direction
Fc9-type-5-icon.png Enable (6)
Enable pin, used to clock data in and out of the device.
Fc9-type-21-icon.png Remap Characters
Fc9-conn-icon.png Display Settings
Fc9-type-14-icon.png Rows
Number of vertical characters that can be shown on the display
Fc9-type-14-icon.png Columns
Number of horizontal characters that can be shown on the display
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-1-icon.png Text Colour
Colour of the font characters drawn on the display
Fc9-type-1-icon.png Text Background
Colour surrounding the font characters drawn on the display
Fc9-type-1-icon.png Display Background
Colour of the background of the display
