| Author
Matrix
| Version
1.1
| Category
LED Array (PCB) component
An LED matrix made up of standard PCB mount 5mm LEDs.
Please click here to download the component source project: FC_Comp_Source_temp/LED_Array_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_Array_pcb.fcfx
Count
| The number of LEDs in the array from 1 to 8.
Output Mode
| Choose a single port for all LEDs, or to allocate them to arbitrary pins.
Port
Polarity
| Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Alignment
| Which 3D axis to align the copies along.
Spacing
| The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs.
Reverse
| Reverse the direction of the LEDs.
Show
| Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Property
| Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Label Position
| Whether to display the pin labels next to each LED
LED color
| The on colour for the LEDs, the off colour is calculated automatically from this.
Label color
| Color of the pin labels.
