Component: LoRa (LAMBDA SX1272) (LAMBDA SX1272) (Wireless)
Revision as of 12:21, 3 February 2023 by Wiki bot (talk | contribs)
Category Wireless
LoRa (LAMBDA SX1272) component
Component to drive the LAMBDA LoRa Transciever module from RF Solutions. Uses an SPI bus connection to the microcontroller. Uses the Semtech SX1272 Transciever IC. Compatible with the LoRaWan network when used with an additional protocol layer.
Please click here to download the component source project: FC_Comp_Source_temp/LoRa_Lambda.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LoRa_Lambda.fcfx
Starts the SPI and configures the LoRa module frequency
ReadReg
ReadReg
Reads a register on the device and returns the value read
- BYTE Address
ReceiveBuffer
ReceiveBuffer
Attempt to read a number of incoming bytes. Returns the number of bytes received
- BYTE Data
- BYTE Count
- UINT Timeout
Time to wait in milliseconds
SetFrequency
SetFrequency
Sets the module frequency
- ULONG Frequency
TransmitBuffer
TransmitBuffer
Attempt to send a number of bytes to be transmitted.
- BYTE Data
Data buffer to transmit
- BYTE Count
Number of bytes to send
WriteReg
WriteReg
- BYTE Address
- BYTE Value
LoRa Properties
Frequency
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
RX Switch
TX Switch
Simulate comms
