Component: MIAC (dsPIC) (MIAC (dsPIC)) (Misc)
Revision as of 12:21, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Misc
MIAC (dsPIC) component
MIAC - Matrix Industrial Automotive Controller (dsPIC)
Please click here to download the component source project: FC_Comp_Source_temp/MIAC_(dsPIC).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/MIAC_(dsPIC).fcfx
DisplayClear
Fc9-comp-macro.png DisplayClear
Clears the display to white space
DisplayCursor
Fc9-comp-macro.png DisplayCursor
Moves the display cursor to the given position. If the cursor is set to the origin at x=0, y=0, then the next character sent to the display will appear in the top left corner.
Fc9-u8-icon.png - BYTE x
Position of the cursor in characters from left to right.
Fc9-u8-icon.png - BYTE y
The line to move the cursor to.
DisplayLight
Fc9-comp-macro.png DisplayLight
Turns the display backlight on or off
Fc9-u8-icon.png - BYTE state
DisplayStart
Fc9-comp-macro.png DisplayStart
Initialise the display ready for use
DrawGlyph
Fc9-comp-macro.png DrawGlyph
Draws a character glyph on the display at position px, py
Fc9-u8-icon.png - BYTE glyph
The glyph ident number
Fc9-u8-icon.png - BYTE px
pixel column relative to the drawing origin (top left)
Fc9-u8-icon.png - BYTE py
pixel row relative to the drawing origin (top left)
Fc9-u8-icon.png - BYTE mode
0=opaque/cleared background, 1=transparent background
DrawLine
Fc9-comp-macro.png DrawLine
Draws or clears a line from start at sx:sy to end at ex:ey
Fc9-u8-icon.png - BYTE sx
Start column position
Fc9-u8-icon.png - BYTE sy
Start row position
Fc9-u8-icon.png - BYTE ex
End column position
Fc9-u8-icon.png - BYTE ey
End row position
1=active pixel, 0=cleared pixel
DrawPixel
Fc9-comp-macro.png DrawPixel
Draws, or clears, a pixel at point x,y
state = 0 clears the pixel, else draws the pixel
DrawRect
Fc9-comp-macro.png DrawRect
Draws a rectangular box from x1,y1 to x2,y2
Fc9-u8-icon.png - BYTE x1
Fc9-u8-icon.png - BYTE y1
Fc9-u8-icon.png - BYTE x2
Fc9-u8-icon.png - BYTE y2
1=draw pixel, 0=clear pixel
GetKeypad
Fc9-comp-macro.png GetKeypad
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255
InputANALOG
Fc9-comp-macro.png InputANALOG
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
Fc9-u8-icon.png - BYTE InputID
The input to read from 1 to 8.
InputANALOG_10Bit
Fc9-comp-macro.png InputANALOG_10Bit
The input to read. From 1 to 8.
Fc9-s16-icon.png - INT Return
InputDIGITAL
Fc9-comp-macro.png InputDIGITAL
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8)
The input number from 1 to 8.
OutputOFF
Fc9-comp-macro.png OutputOFF
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4)
Fc9-u8-icon.png - BYTE TransID
1 to 4 (Outputs A to D)
OutputON
Fc9-comp-macro.png OutputON
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4)
PrintASCII
Fc9-comp-macro.png PrintASCII
Prints the given character to the display at the current cursor position and increments the cursor position.
Fc9-u8-icon.png - BYTE Char
ASCII code of the character to print.
PrintFormattedNumber
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Prints the given number to the display starting at the current cursor position and moves the cursor position.
Fc9-s16-icon.png - INT n
PrintString
Fc9-comp-macro.png PrintString
Prints the given character string to the display at the current cursor position and moves the cursor position.
The string to send to the display.
RelayOFF
Fc9-comp-macro.png RelayOFF
Turns off the requested relay given by parameter RelayID, values 1 to 4
Fc9-u8-icon.png - BYTE RelayID
The relay to turn off. From 1 to 4.
RelayON
Fc9-comp-macro.png RelayON
Turns on the requested relay given by parameter RelayID, values 1 to 4
The relay to turn on from 1 to 4.
