Author
Matrix TSL
Version
1.0
Category
Comms: Networking
TCP/IP (W5500) component
TCP/IP component designed to work with the W5500 device used on the ETH WIZ Click
Please click here to download the component source project: FC_Comp_Source_temp/TCPIP_W5500.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/TCPIP_W5500.fcfx
HTTP Server
Simple example showing the W5500 component being used stand alone to create a web server.
W5500 Webserver
Network Comms
Here are some examples using the Network Communication component linked to the W5500 component.
NetworkComms W5500 Client
NetworkComms W5500 Webserver
CreateIPSocket
CreateIPSocket
Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
- BYTE
Specifies the communications channel 0-3
- BYTE
Protocol
Specifies which IP protocol to use
- BYTE
Broadcast
Allows broadcast type packets to be sent and received
- BYTE
CreateMACSocket
CreateMACSocket
This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE
Promiscuous
Receive everything (1) or just data bound for your MAC (0)
- BYTE
Broadcast
Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE
Error
Allowsmessages with errors to be accepted (1) or rejected (0)
- BYTE
CreateTCPSocket
CreateTCPSocket
This macro creates a socket for sending and receiving TCP data.
- BYTE
- UINT
Src_Port
Port Number
- BYTE
CreateUDPSocket
CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
- BYTE
- UINT
Src_Port
Port Number
- BYTE
CreateUDPSocket_Sim
CreateUDPSocket_Sim
- BYTE
- UINT
Src_Port
Port Number
- BYTE
GetSocketStatus
GetSocketStatus
This returns the state of the requested channel's socket.
- BYTE
- BYTE
Resets and initialises the W5500 IC. Sets up the gateway address, subnet mask, device IP address and device MAC address. This macro must be called before any other TCP_IP component macros. Returns 1 to indicate successful communication.
- BYTE
MIAC_Module_GetData
MIAC_Module_GetData
- BYTE
Index
- BYTE
MIAC_Module_Message
MIAC_Module_Message
- UINT
CAN_ID
- UINT
CMD_ID
- BYTE
MIAC_Module_PushData
- BYTE
Data
MIAC_Module_SetData
MIAC_Module_SetData
- BYTE
Count
- BYTE
D0
- BYTE
D1
- BYTE
D2
- BYTE
D3
- BYTE
D4
- BYTE
D5
RxDataAvailable
RxDataAvailable
This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
- BYTE
- BYTE
RxDataSize
RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE
- UINT
RxDataSize_Sim
RxDataSize_Sim
- BYTE
- BYTE
RxFlushData
RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE
RxFlushData_Sim
RxFlushData_Sim
- BYTE
RxMatchMyIP
RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE
- BYTE
RxMatchMyMAC
RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE
- BYTE
RxMatchMyMAC_Sim
RxMatchMyMAC_Sim
- BYTE
- BYTE
RxMatch_2_Bytes
RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
Specifies the value of the first byte
- BYTE
Byte2
Specifies the value of the second byte
- BYTE
RxMatch_2_Bytes_Sim
RxMatch_2_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
RxMatch_4_Bytes
RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
Specifies the value of the third byte
- BYTE
Byte4
Specifies the value of the fourth byte
- BYTE
RxMatch_4_Bytes_Sim
RxMatch_4_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
RxMatch_6_Bytes
RxMatch_6_Bytes
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
Specifies the value of the fifth byte
- BYTE
Byte6
Specifies the value of the sixth byte
- BYTE
RxReadByte
RxReadByte
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
RxReadByte_Sim
RxReadByte_Sim
- BYTE
- BYTE
RxReadHeader
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE
- BYTE
Idx
Specifies the byte index to return
- BYTE
RxReadString
RxReadString
A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Length
- STRING
RxSkipBytes
RxSkipBytes
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE
- BYTE
Count
Specifies how many bytes to skip
SetDestination
SetDestination
This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
- BYTE
- BYTE
Dst_IP0
Specifies the first byte of an IP address
- BYTE
Dst_IP1
Specifies the second byte of an IP address
- BYTE
Dst_IP2
Specifies the third byte of an IP address
- BYTE
Dst_IP3
Specifies the fourth byte of an IP address
- UINT
Dst_Port
Destination Port
- BYTE
SetGateway
SetGateway
This macro sets up the Internet E-Block's Gateway address. In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
First Byte of IP address
- BYTE
IP1
Second Byte of IP address
- BYTE
IP2
Third Byte of IP address
- BYTE
IP3
Fourth Byte of IP address
SetMACAddress
SetMACAddress
This macro sets up the Internet E-Block's MAC address. In most circumstances, this macro will not be required as the MAC address setting in the component property page will remain constant throughout your application.
- BYTE
MAC0
First Byte of address
- BYTE
MAC1
Second Byte of address
- BYTE
MAC2
Third Byte of address
- BYTE
MAC3
Fourth Byte of address
- BYTE
MAC4
- BYTE
MAC5
Fifth Byte of address
SetMyIP
SetMyIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
SetSubnetMask
SetSubnetMask
This macro sets up the Internet E-Block's Subnet Mask. In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TCPClose
TCPClose
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE
TCPConnect
TCPConnect
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- UINT
Dst_Port
Destination Port
- BYTE
TCPListen
TCPListen
This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
- BYTE
TxEnd
TxEnd
Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE
TxSendByte
TxSendByte
This macro fills the specified channel's transmit buffer with data.
- BYTE
- BYTE
Data
Data byte to append to Tx buffer.
TxSendByte_Sim
TxSendByte_Sim
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
- BYTE
- BYTE
Data
TxSendMyIP
TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE
TxSendMyMAC
TxSendMyMAC
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE
TxSendString
TxSendString
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
- BYTE
- STRING
Data
- BYTE
Length
TxStart
TxStart
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Sim Type
Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / Injector - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
TCP Simulation
Network Interface
List of network interfaces connected to the PC. Sets which interface we are communicating via.
