Component: UART SCADA (CAL) (Misc)
Revision as of 12:22, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.1
Category Misc
UART SCADA component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the UART peripheral. Includes simulation functionality to commmunicate via a COM port or an Injector component. Also includes timestamped logging via the console and Data Recorder trace monitoring support.
Please click here to download the component source project: FC_Comp_Source_temp/UART_SCADA.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/UART_SCADA.fcfx
GetConsoleHandle
Init
Fc9-comp-macro.png Init
Initialize the component with the specified properties
Receive
Fc9-comp-macro.png Receive
Receive a Character
Fc9-u16-icon.png - UINT Timeout
Period to wait for the character to be received
Fc9-s16-icon.png - INT Return
ReceiveByteArray
Fc9-comp-macro.png ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
A byte array variable to hold the received data
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to try and receive
Max amount of time in ms to wait between bytes
ReceiveString
Fc9-comp-macro.png ReceiveString
Receives a string of bytes and returns the number of bytes received.
Fc9-string-icon.png - STRING StringData
ScanForDeviceID
Fc9-comp-macro.png ScanForDeviceID
Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found.
Fc9-string-icon.png - STRING HWID
Example: "VID_12BF&PID_0101"
Send
Fc9-comp-macro.png Send
Send the Character
Fc9-u16-icon.png - UINT Char
The Character to send
SendByteArray
Fc9-comp-macro.png SendByteArray
Transmits an array of bytes via the UART peripheral
Data to transmit
Number of bytes to send from the array
SendString
Fc9-comp-macro.png SendString
Transmits a string of bytes via the UART peripheral
Data String to transmit
Uninit
Fc9-comp-macro.png Uninit
Un-initialize the UART and release the resources
Fc9-type-7-icon.png Component Enable
A global flag to enable or disable the UART component from producing code. Useful for generating components with multiple communications options.
Fc9-conn-icon.png Runtime
Fc9-type-21-icon.png Console Columns
Fc9-type-7-icon.png Auto Close
Auto close the port on Sim stop event
Fc9-type-16-icon.png Data Source
Fc9-type-16-icon.png COM Port
Lists all the current available COM port hardware on your PC.
Fc9-type-7-icon.png Refresh Ports
Fc9-type-21-icon.png Baud Rate
COM port data rate in bits per second
