Component: Switch (Slide, PCB) ()
| Author | Matrix Ltd |
| Version | 1.2 |
| Category |
Switch (Slide, PCB) component
Subminiature slide switch with black tang, PCB mount.
Please click here to download the component source project: FC_Comp_Source_temp/sw_slide_sub_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/sw_slide_sub_pcb.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
