Component: BBC Weather Forecast (Comms: IoT/Cloud)
Revision as of 13:08, 7 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: IoT/Cloud
BBC Weather Forecast component
Easily allows you to collect three day forecasted weather metrics for your area using the BBC Weather data service. Supports Min/Max temperature, Wind Direction, Wind Speed, Visibility, Pressure, Humidty, UV Risk, Pollution and Sun Rise/Set times for your selected area.
Please click here to download the component source project: FC_Comp_Source_BBCWeatherForecast.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_BBCWeatherForecast.fcfx
Here is a basic example to read the three day forecast data and report the information on a graphical display.
BBCWeatherForecastDemo
The location can be set by adjusting the BBC Weather location property, see the component property tooltips for more information on how to do this.
On an embedded device you would need a TCP/IP component to allow the communications to the BBC server. This then links to the Network Comms component.
GetDayName
GetDayName
Gets the name of the currently selected day as a string.
- STRING Return
GetDaySummary
GetDaySummary
Gets the summary of the currently selected day as a string.
- STRING Return
GetHumidity
GetHumidity
Reads the forecast humidity in Relative Humdity for the selected day.
GetLocationName
GetLocationName
Reads the reported location name as a string.
- STRING Return
GetMaxTemperature
GetMaxTemperature
Reads the forecast maximum temperature in the selected scale for the selected day.
- BOOL Scale
0 = Celcius, 1 = Farenheit
- INT Return
GetMinTemperature
GetMinTemperature
Reads the forecast minimum temperature in the selected scale for the selected day.
- BOOL Scale
- INT Return
GetPollution
GetPollution
Reads the forecast pollution as a string for the selected day.
- STRING Return
GetPressure
GetPressure
Reads the forecast air pressure in milli bar (mb) for the selected day.
GetSunrise
GetSunrise
Reads the forecast sunrise time as a string for the selected day.
- STRING Return
GetSunset
GetSunset
Reads the forecast sunset time as a string for the selected day.
- STRING Return
GetUVRisk
GetUVRisk
Reads the forecast UV Risk for the selected day.
GetVisibility
GetVisibility
Reads the forecast visibility for the selected day.
- STRING Return
GetWindDirection
GetWindDirection
Reads the forecast wind direction as a string for the selected day.
- STRING Return
GetWindSpeed
GetWindSpeed
Reads the reported wind speed in MPH for the selected day.
Sets up the component ready to collect weather data.
RequestData
RequestData
Requests data about your selected location from the BBC weather service. Returns true if the request was successful. Must be called before trying to call any of the GetXXX macros.
- BOOL Return
SetForecastDay
SetForecastDay
Chooses which day of the three day forecast to look at.
- BYTE Day
0 = Today, 1 = Tomorrow, 2 = Day After Tomorrow
SetLocationCode
SetLocationCode
Allows the location code to be altered from the default location code set in the component properties. After changing the location the RequestData macro must be called to refresh the forecast variables.
- STRING NewLocation
New location string, see Location property tooltip for more info.
LinkTo
BBC IP Address
IP Address linked to the following URL: weather-broker-cdn.api.bbci.co.uk
Location Code
BBC code for your area. In a web browser go to www.bbc.co.uk/weather/ Then type in your city in the search bar and your code will be shown at the end of the URL. For example Manchester in the UK = 2643123 In the UK you can also use the first half of your post code, e.g. HX1
Receive Timeout
Maximum time to wait for valid incoming data.
