Component: Delay (DSP Operators)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Delay component
Allows an adjustable delay to be inserted into the DSP system
Please click here to download the component source project: FC_Comp_Source_DSP_Delay.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Delay.fcfx
Here is a simple example file for the Delay component.
FC6 Icon.png Delay
The DelayADC component is used to set the amount of delay that the component provides 0-2550 samples in steps of 10 samples.
The Input ADC component is used to pass a variable value into the DSP chain to allow the delay to be simulated.
Here is a picture showing the response of the delay component using the data recorder window.
Delay
Fc9-comp-macro.png Delay
Passes a single value from a buffer into the delay buffer and spits out a delayed value at the other end
DelayArray
Fc9-comp-macro.png DelayArray
Passes an entire buffer into the delay buffer and spits out a delayed version of the buffer at the other end
PresetDelay
Fc9-comp-macro.png PresetDelay
Presets the contents of the delay buffer with the specified value.
Fc9-u16-icon.png - UINT Value
SetDelaySize
Fc9-comp-macro.png SetDelaySize
Specifies the number of values in the delay buffer to allow the length of the delay to be adjustable during runtime.
Fc9-u16-icon.png - UINT Delay_Count
Fc9-type-16-icon.png Connect To
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-type-16-icon.png Direction
Sets the data direction flow of the component
Fc9-conn-icon.png Delay
Fc9-type-14-icon.png Initial Delay Count
The initial delay that will be used at startup
Fc9-type-14-icon.png Max Delay Count
The maximum number of values to delay the incoming signal by
Fc9-type-14-icon.png Initial Value
Value used to preset the delay buffer.
Fc9-conn-icon.png Delay Calculation
Fc9-type-15-icon.png Sample Rate (Hz)
Sample rate used to generate some useful calculations
Fc9-type-15-icon.png Max Delay (s)
Maximum possible delay in seconds at the specified sample rate
Fc9-type-15-icon.png Initial Delay (s)
Initial delay in seconds at the specified sample rate
