Component: Output CSV (DSP Outputs)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Outputs
Output CSV component
Allows the values from a buffer to be output directly into a .CSV format file. Either a value at a time or as an array.
Please click here to download the component source project: FC_Comp_Source_DSP_FileOutput.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_FileOutput.fcfx
CloseFile
Fc9-comp-macro.png CloseFile
Closes a file
OpenFile
Fc9-comp-macro.png OpenFile
Opens a file ready for writing. Returns 1 if file opened OK. Automatically called by the WriteValue/WriteArray macros with the default values set by the component properties if not already called by the program.
Filename, must be an 8.3 formatted filename in embedded.
Fc9-bool-icon.png - BOOL ExistingData
0=KeepAndAppend, 1=Clear
WriteArray
Fc9-comp-macro.png WriteArray
Writes a buffer of values from the selected DSP buffer to the CSV file. FAT component must be initialised before calling this macro.
WriteValue
Fc9-comp-macro.png WriteValue
Writes a single value from the selected DSP buffer to the CSV file. FAT component must be initialised before calling this macro.
Fc9-type-16-icon.png Connect To 0
Fc9-conn-icon.png CSV File
Fc9-type-16-icon.png LinkTo
Fc9-type-16-icon.png Number of Inputs
The number of inputs the multiplexer can switch between.
Fc9-type-10-icon.png Filename
Name of the file to write DSP data to.
Fc9-type-16-icon.png Existing Data
Decides what to do when opening a file that already exists.
