Component: Multiplex (DSP Operators)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Multiplex component
Allows multiple input buffers to be multiplexed to a single output buffer.
Please click here to download the component source project: FC_Comp_Source_DSP_Mpx.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Mpx.fcfx
Multiplex
Multiplex
Passes a single value from the selected input buffer into the output buffer.
MultiplexArray
MultiplexArray
Passes an entire buffer through the multiplexer.
SetMultiplexSource
SetMultiplexSource
Specifies the source buffer to copy through to the output buffer.
- BYTE Source
- BOOL ResetInputIndex
0=Leave Index, 1=Reset Index to 0
Connect To 0
Connect To 1
Buffer Size
Buffer Type
Sets the buffer data type.
Multiplex
Number of Inputs
The number of inputs the multiplexer can switch between.
