| Category | E-blocks 2 |
GLCD Monochrome component
Graphical display component designed to work with the EB2 BL0139 Downstream E-block.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Mono_GLCD_BL0139.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Mono_GLCD_BL0139.fcfx
BPlot
|   | BPlot |
|  - BYTE | X1 |
|  - BYTE | Y1 |
|  - VOID | Return |
ClearDisplay
|   | ClearDisplay |
|  - VOID | Return |
DrawCircle
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Transparent |
|  - BYTE | Solid |
|  - VOID | Return |
DrawEllipse
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
DrawLine
|   | DrawLine |
|  - BYTE | X1 |
|  - BYTE | Y1 |
|  - BYTE | X2 |
|  - BYTE | Y2 |
|  - VOID | Return |
DrawRectangle
|   | DrawRectangle |
|  - BYTE | X1 |
|  - BYTE | Y1 |
|  - BYTE | X2 |
|  - BYTE | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
Goto_XY
|   | Goto_XY |
|  - BYTE | X |
|  - BYTE | Y |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
Plot
|   | Plot |
|  - BYTE | X1 |
|  - BYTE | Y1 |
|  - VOID | Return |
Print
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - VOID | Return |
ReadFontStat
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
ReadFontWidth
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Character |
|  - BYTE | Return |
SetBackgroundColour
|   | SetBackgroundColour |
| Specifies the colour of the foreground |
|  - BYTE | PixelColour |
| 0=White, 1=Black |
|  - VOID | Return |
SetDisplayOrientation
|   | SetDisplayOrientation |
|  - BYTE | Orientation |
|  - VOID | Return |
SetFontScaler
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
SetForegroundColour
|   | SetForegroundColour |
| Specifies the colour of the foreground. |
| 0=White, 1=Black |
|  - VOID | Return |
Write_Command
|   | Write_Command |
|  - BYTE | Command |
|  - VOID | Return |
Write_Data
|   | Write_Data |
|  - BYTE | data |
|  - VOID | Return |
|   | Properties |
|   | Version |
|   | Dimensions |
|   | Pixel Height |
|   | Pixel Width |
|   | Colour |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Bit Depth |
|   | Color Bit Depth |
| Number of bits of colour depth available on the display |
|   | Red Bit Depth |
| Number of bits of Red colour depth on the display |
|   | Green Bit Depth |
| Number of bits of Green colour depth on the display |
|   | Blue Bit Depth |
| Number of bits of Blue colour depth on the display |
|   | Connections |
|   | CS |
| Chip select pin |
|   | Reset |
|   | A0 |
| Address pin to tell the display if we are sending commands or data |
|   | Data Pin |
|   | Clock Pin |
|   | Fonts |
|   | Font Count |
|   | Font 0 |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Simulation |
|   | Display Method |
| Chooses which method to use when drawing to the gLCD component The bitmap is the more common mode but may run slowly on some machines. The point cloud should run faster but may use more memory. |
|   | Component Label |
|   | Component Label Scale |
| The label scale can be change if the amout of text is too wide for the display |
