Component: File (RPI) (File)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.7
Category File
File (RPI) component
File component allowing access to read and write files on the Raspberry Pi file system.
Please click here to download the component source project: FC_Comp_Source_File_RPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_File_RPI.fcfx
AppendByteToFile
AppendByteToFile
- BYTE Data
AppendStringToFile
AppendStringToFile
- STRING Data_String
CloseFile
CloseFile
CreateFile
CreateFile
- STRING Filename
DeleteFile
DeleteFile
- STRING Filename
MoveToNextFileSector
Not currently implemented on the RPI
- BYTE ForceNextSector
OpenFile
OpenFile
Searches for and opens a file for reading or writing from within the current directory on the disk. Returns 0 for success.
- STRING Filename
8.3 filename of the file we are trying to open e.g. "file.txt"
OpenFolder
OpenFolder
- STRING Folder_Name
ReadByteFromFile
ReadByteFromFile
Reads a byte from the currently open file. Auto increments the position in the file. A return value of 0 may signify the end of the file has been reached (depending on the contents of the file).
ReadByteFromIndex
ReadByteFromIndex
Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer.
- ULONG Address
ReadFileLength
ReadFileLength
- INT Return
ReadFileSize
ReadFileSize
Reads the entire size of the current file in bytes.
- ULONG Return
ReadStringFromFile
ReadStringFromFile
Reads a string from the currently open file. Auto increments the position in the file. An empty string signifies the end of the file has been reached.
- UINT NumBytes
Maximum number of bytes to attempt to read
- BYTE EndChar
Ends the string if the value specified is found, default is 0
- STRING Return
SetFileIndex
SetFileIndex
- BYTE File_Index
Range: 0 to 4
WriteByteToBuffer
WriteByteToBuffer
- UINT Address
- BYTE Data
WriteFileSector
WriteFileSector
Root Folder
Root location on the RPI where the files will be stored
File Count
Number of simultaneous files we want to access.
Sim Root Folder
