Component: Formula AllCode API (AllCode)
Author | Matrix Ltd |
Version | 1.2 |
Category | AllCode |
- 1 Formula AllCode API component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 Backwards
- 5.2 CardBitmap
- 5.3 CardCreate
- 5.4 CardErase
- 5.5 CardInit
- 5.6 CardOpen
- 5.7 CardPlayback
- 5.8 CardReadByte
- 5.9 CardRecordMic
- 5.10 CardWriteByte
- 5.11 EncoderRead
- 5.12 EncoderReset
- 5.13 Forwards
- 5.14 GetConsoleHandle
- 5.15 GetProp
- 5.16 LCDBacklight
- 5.17 LCDClear
- 5.18 LCDDrawLine
- 5.19 LCDDrawPixel
- 5.20 LCDDrawRect
- 5.21 LCDPrintNumber
- 5.22 LCDPrintString
- 5.23 LCDVerbose
- 5.24 LEDOff
- 5.25 LEDOn
- 5.26 LEDWrite
- 5.27 Left
- 5.28 PlayNote
- 5.29 ReadAllSensors
- 5.30 ReadAllValue
- 5.31 ReadAxis
- 5.32 ReadBearing
- 5.33 ReadIR
- 5.34 ReadLight
- 5.35 ReadLine
- 5.36 ReadMic
- 5.37 ReadSwitch
- 5.38 Right
- 5.39 SampleAccel
- 5.40 SampleMag
- 5.41 ServoAutoMoveToPosition
- 5.42 ServoDisable
- 5.43 ServoEnable
- 5.44 ServoSetAutoMoveSpeed
- 5.45 ServoSetPosition
- 5.46 SetLogoSpeed
- 5.47 SetMotors
- 5.48 SetProp
- 6 Property reference
A simulation only component to allow the Formula AllCode robot to be controlled via it's API interface and Bluetooth data connection without having to compile or re-program the robot.
Please click here to download the component source project: FC_Comp_Source_FormulaAllCode_API.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_FormulaAllCode_API.fcsx
The COM port for the Formula AllCode can be set via the panel properties which can be exposed to the SCADA runtime user.
LED Control
Controls the LEDs on the Formula AllCode by collecting the analogue value of a potentiometer on the simulation panel and sending the value to the robot.
Motor Control Using Keypad
Uses the keypad on the simulation panel to control the speed and direction of the motors. Key 2 drives the robot forwards, 8 drives backwards, 4 and 6 turn the robot on the spot.
Motor Control Using Joystick
A simple example showing how to drive the Formula AllCode robot around in API mode using a panel based joystick control.
Proximity Alarm
Reads the front IR sensor on the Formula AllCode from the Flowcode simulation. If a near object is sensed then the Flowcode simulation will speak the word "Hello" using the Speech component.
Driving Simulation using the API component
An example showing how to use the API component to drive the Formula AllCode robot component on the simulation panel.
JCB Bot Blog
Blog with example code showing how to drive the Formula AllCode robot using Key Mappings and how to add extra features such as a 3D printed cover and servo motors to operate a digger arm and bucket.
Backwards
Backwards |
Drives the robot backwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
CardBitmap
CardBitmap |
Displays a monochrome bitmap read from the card on the LCD | |
X |
Range 0-127 | |
Y |
Range 0-31 | |
Filename |
Return |
CardCreate
CardCreate |
Attempts to create a file on the SD card 255=Error, 1=File Already Exists, 0=Create OK | |
Filename |
Return |
CardErase
CardErase |
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK | |
Filename |
Return |
CardInit
CardInit |
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK | |
Return |
CardOpen
CardOpen |
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK | |
Filename |
Return |
CardPlayback
CardPlayback |
Plays back a .Wav file audio stream from the card | |
Filename |
Return |
CardReadByte
CardReadByte |
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end | |
Return |
CardRecordMic
CardWriteByte
CardWriteByte |
Appends a byte to the end of the currently open file | |
Data |
Return |
EncoderRead
EncoderRead |
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit. | |
index |
0=Left, 1=Right | |
Return |
EncoderReset
EncoderReset |
Resets the motor encoder counters | |
Return |
Forwards
Forwards |
Drives the robot forwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
GetConsoleHandle
GetConsoleHandle |
Gets the handle to the console allowing data displaying on the panel etc. | |
Return |
GetProp
GetProp |
Allows the property filter for the COM port list to be copied to a parent component. | |
PropName |
Return |
LCDBacklight
LCDBacklight |
Allows the LCD backlight brighntess to be adjusted | |
Intensity |
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness | |
Return |
LCDClear
LCDClear |
Clears the LCD | |
Return |
LCDDrawLine
LCDDrawLine |
Allows a single pixel width line to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
LCDDrawPixel
LCDDrawPixel |
Allows a single pixel on the LCD to be set or cleared | |
X |
X Pixel 0-127 | |
Y |
Y Pixel 0-31 | |
State |
0=White (Off), 1=Black (On) | |
Return |
LCDDrawRect
LCDDrawRect |
Allows a rectangle to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
LCDPrintNumber
LCDPrintNumber |
Prints a 16-bit signed number to the LCD | |
X |
X Pixel 0-127 | |
Y |
LCD Y coordinate 0-31 | |
Number |
Range -32768 to 32767 | |
Return |
LCDPrintString
LCDPrintString |
Prints a string to the LCD | |
X |
X Pixel 0-127 | |
Y |
LCD Y Coordinate 0-31 | |
Data |
Return |
LCDVerbose
LCDVerbose |
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on | |
State |
0=Off 1=On | |
Return |
LEDOff
LEDOff |
Clears a single LED 0-7 | |
index |
Range: 0-7 | |
Return |
LEDOn
LEDOn |
Sets a single LED 0-7 | |
index |
Range: 0-7 | |
Return |
LEDWrite
LEDWrite |
Sets the value of the LEDs as an 8-bit output | |
Value |
LED value 0=All Off, 255 = All On | |
Return |
Left
Left |
Rotates the robot left - waits for the angle to be traversed before returning | |
Angle |
Angle to turn in degrees | |
Return |
PlayNote
PlayNote |
Plays a note using the speaker on the FA | |
Note |
Range 1 to 65535 in Hz | |
Delay |
Number of milliseconds to play the note for | |
Return |
ReadAllSensors
ReadAllSensors |
Samples all of the robot's sensors at once, storing the values locally | |
Return |
ReadAllValue
ReadAllValue |
Reads a single value stored from the read all command Index dictates which sensor value to read | |
Index |
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel | |
Return |
ReadAxis
ReadAxis |
Reads a single X/Y/Z axis from the accelerometer sensor. | |
index |
0=X, 1=Y, 2=Z | |
Return |
ReadBearing
ReadBearing |
Reads the compass bearing based on the degrees clockwise from magnetic north. | |
Return |
ReadIR
ReadLight
ReadLight |
Reads the light sensor 0-4095 - 4095 = Max Brightness | |
Return |
ReadLine
ReadLine |
Reads one of the IR line sensors 0-1 0=Left, 1=Right | |
index |
0=Left, 1=Right | |
Return |
ReadMic
ReadMic |
Reads the microphone sensor 0 - 4095 | |
Return |
ReadSwitch
ReadSwitch |
Read the switch value | |
index |
0 (left) or 1 (right) | |
Return |
Right
Right |
Rotates the robot right - waits for the angle to be traversed before returning | |
Angle |
Return |
SampleAccel
SampleAccel |
Samples the accelerometer 0 = no new data, 1 = new data available | |
Return |
SampleMag
SampleMag |
Samples the magnetometer 0 = no new data, 1 = new data available | |
Return |
ServoAutoMoveToPosition |
Allows one of the servo positions to move gradually to a new position | |
Channel |
Range 0-3 | |
Position |
Range 0-255 | |
Return |
ServoDisable
ServoDisable |
Allows one of the servo outputs 0-3 to be disabled | |
Channel |
Range 0-3 | |
Return |
ServoEnable
ServoEnable |
Allows one of the servo outputs 0-3 to be enabled | |
Channel |
Range 0-3 | |
Return |
ServoSetAutoMoveSpeed |
Changes the speed of the auto movements Default - 1 | |
Speed |
Range 1-50 | |
Return |
ServoSetPosition
ServoSetPosition |
Allows one of the servo positions to be assigned | |
Channel |
Range 0-3 | |
Position |
Range 0-255 | |
Return |
SetLogoSpeed
SetLogoSpeed |
Sets the speed of logo movements | |
Speed |
Logo Speed 1-100 - Default 40 | |
Return |
SetMotors
SetMotors |
Sets the motor speeds without feedback Range -100 to 100 | |
Left |
Right |
Return |
SetProp
SetProp |
Allows the COM port property to be set from a parent component. | |
PropName |
PropVal |
Return |
