Component: GLCD (SH1106) SPI (Graphical Monochrome)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Graphical Monochrome
GLCD (SH1106) SPI component
Graphical display component designed to work with the SH1106 type monochrome displays. Transfers data using a 4-wire SPI interface.
Please click here to download the component source project: FC_Comp_Source_GLCD_SH1106_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SH1106_SPI.fcfx
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
0=White, 1=Black
Write_Command
Fc9-comp-macro.png Write_Command
Fc9-u8-icon.png - BYTE Command
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-5-icon.png DC
Fc9-type-5-icon.png Reset
Reset pin on the display, used during initialise to force a clean startup of the display
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Fc9-conn-icon.png Communications
Fc9-type-16-icon.png API
