Component: GLCD (T6963C) (Graphical Monochrome)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Graphical Monochrome
GLCD (T6963C) component
A Graphical LCD component to drive displays fitted with a T6963C controller IC.
Please click here to download the component source project: FC_Comp_Source_GLCD_T6963C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_T6963C.fcfx
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE Pixel_Colour
0=White, 1=Black
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Pixel_Colour
0=White, 1=Black
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
WR
RD
CE
CD
Reset
FS
Data Uses Port
Does the data bus use a whole 8-bit port if so then set the property to yes to speed up execution. Otherwise if the data bus uses individual pins then set the property to no.
Data Port
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
