Component: J1939 (Misc)
Jump to navigationJump to search| Author | |
| Version | 1.1 |
| Category | Misc |
- 1 J1939 component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 Get_Address
- 5.2 Get_Status
- 5.3 Initialise
- 5.4 Message_Data_Clear
- 5.5 Message_Data_Read_SPN
- 5.6 Message_Data_Set
- 5.7 Message_Data_Write_SPN
- 5.8 Process
- 5.9 Rx_Message_Check
- 5.10 Rx_Message_Data
- 5.11 Rx_Message_Source
- 5.12 Rx_Transfer_Check
- 5.13 Rx_Transfer_Data
- 5.14 Tx_Message_Send
- 5.15 Tx_Transfer_Send
- 6 Property reference
J1939 component
Please click here to download the component source project: FC_Comp_Source_J1939.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_J1939.fcfx
Get_Address
|   | Get_Address |
| Returns the device (ECU) actual address | |
|  - BYTE | Return |
Get_Status
|   | Get_Status |
| Returns the system status. 0 = Ready. 1 = Waiting address claim | |
|  - BYTE | Return |
|   | Initialise |
| Initialise the CAN network and J1939 protocol | |
|  - BYTE | Preferred_Address |
| Preferred Address (Requested Address) | |
|  - BYTE | Return |
Message_Data_Clear
|   | Message_Data_Clear |
| Clear the CAN Data Buffer | |
|  - BYTE | DataBuffer |
|  - VOID | Return |
|   | Message_Data_Read_SPN |
| Read the SPN value from the CAN data buffer | |
|  - UINT | SPN |
|  - UINT | Return |
Message_Data_Set
|   | Message_Data_Set |
| Set all data in CAN Data Buffer to given value. e.g. 0 or 0xFF | |
|  - BYTE | Value |
|  - VOID | Return |
|   | Message_Data_Write_SPN |
| Write the SPN value to the CAN data buffer | |
|  - UINT | SPN |
|  - UINT | Value |
|  - BYTE | Return |
Process
|   | Process |
| Does the message processing. Call this often. | |
|  - UINT | TimeElapsed |
| Time elapsed since last call, in mS. Can be zero for frequent calling. | |
|  - BYTE | Return |
Rx_Message_Check
|   | Rx_Message_Check |
| If a data message has been received returns the PGN,otherwise 0 | |
|  - UINT | Return |
Rx_Message_Data
|   | Rx_Message_Data |
| Returns the DLC and data of the last received message | |
|  - BYTE | Return |
Rx_Message_Source
|   | Rx_Message_Source |
| Returns the Source Address of the last received message | |
|  - BYTE | Return |
Rx_Transfer_Check
|   | Rx_Transfer_Check |
| Check for incoming multipart data transfers. If received, returns the PGN else 0 | |
|  - ULONG | Return |
Rx_Transfer_Data
|   | Rx_Transfer_Data |
| Returns the byte count and data of the transfer message data | |
| Buffer to receive copied data | |
|  - UINT | Size |
| Size (byte count) of buffer | |
|  - UINT | Return |
Tx_Message_Send
|   | Tx_Message_Send |
| Send the prepared CAN message | |
|  - UINT | PGN |
|  - BYTE | DLC |
|  - BYTE | Return |
Tx_Transfer_Send
