| Author | Matrix Ltd |
| Version | 2.1 |
| Category | Alphanumeric |
LCD (Electronic Assembly) component
Generic configurable alphanumeric LCD display component based on the OLED Hitachi like display controller ICs from Electronic Assembly wiith selectable 4/8 bit interface. These have a very slight timing difference from the standard Hitachi displays.
Please click here to download the component source project: FC_Comp_Source_LCD-W162-XBLW.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD-W162-XBLW.fcfx
Clear
|   | Clear |
| Clears the entire contents of the display. |
|  - VOID | Return |
ClearLine
|   | ClearLine |
| Clears a single line on the display and then moves the cursor to the start of the line to allow you to start populating the line with data. |
|  - BYTE | Line |
| The line to clear, zero being the first (top) line of the display |
|  - VOID | Return |
Command
|   | Command |
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet. |
|  - BYTE | instruction |
| Send a defined command to the LCD Screen. See datasheet for supported commands. |
|  - VOID | Return |
Cursor
|   | Cursor |
| Moves the cursor on the LCD Display |
|  - BYTE | x |
| Set the cursor position in the X plane, 0 is the left most cell |
|  - BYTE | y |
| Set the cursor position in the Y plane, 0 is the top most cell |
|  - VOID | Return |
PrintAscii
|   | PrintAscii |
| Takes the ascii value for a character and prints the character |
|  - BYTE | character |
| Holds an ascii value. |
|  - VOID | Return |
PrintFloat
|   | PrintFloat |
| Print a Float number rounded up to a specified amount of decimal places. |
|  - FLOAT | Number |
| Enter the number or variable to print to the LCD |
|  - BYTE | DecimalPlaces |
| Enter how many decimal places to round up to (1 - 6) |
|  - VOID | Return |
PrintFormattedNumber
|   | PrintFormattedNumber |
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295 |
|  - ULONG | Number |
|  - BOOL | Format |
| 0=Signed, 1=Unsigned |
|  - VOID | Return |
|   | PrintNumber |
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 |
|  - INT | Number |
|  - VOID | Return |
PrintString
|   | PrintString |
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro |
|  - STRING | Text |
| Enter the text or variable to print to the LCD |
|  - VOID | Return |
RAMWrite
|   | RAMWrite |
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory |
|  - BYTE | Index |
| Values 0 to 7 |
|  - BYTE | d0 |
|  - BYTE | d1 |
|  - BYTE | d2 |
|  - BYTE | d3 |
|  - BYTE | d4 |
|  - BYTE | d5 |
|  - BYTE | d6 |
|  - BYTE | d7 |
|  - VOID | Return |
RawSend
|   | RawSend |
| Sends data to the LCD display |
|  - BYTE | data |
| The data byte to send to the LCD |
|  - BOOL | type |
| A boolean to indicate command type: true to write data, false to write a command |
|  - VOID | Return |
ScrollDisplay
|   | ScrollDisplay |
| Scrolls the display left or right by a number of given positions. |
|  - BYTE | Position |
| Holds the number of positions to shift the display |
|  - BYTE | direction |
| 0 = left, 1 = right |
|  - VOID | Return |
Start
|   | Start |
| Startup routine required by the hardware device. Automatically clears the display after initialising. |
|  - VOID | Return |
|   | Properties |
|   | Connections |
|   | Interface mode |
| Choose between 4-bit mode, 8-bit mode and 8-bit mode using a port instead of individual pins to improve code efficiency. |
|   | Data 0 (11 / 7) |
| Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode |
|   | Data 1 (12 / 8) |
| Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode |
|   | Data 2 (13 / 9) |
| Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode |
|   | Data 3 (14 / 10) |
| Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode |
|   | Register Select (4) |
| Register Select Pin - Informs the display if a command or data is about to be sent. |
|   | Enable (6) |
| Enable pin - Used to synchronise data writes to the display |
|   | Use Read/Write Pin |
| Set to "true" if the displays R/W pin is not hard wired. Set to "false" if the R/W pin is wired to ground. |
|   | Display Settings |
|   | Rows |
| Number of lines of characters the LCD can display. |
|   | Columns |
| Number of characters the LCD can display on a single line. |
|   | Display Simulation |
|   | Component Label |
|   | Component Label Scale |
| The label scale can be change if the amout of text is too wide for the display |
|   | Text Colour |
| Colour of the font characters drawn on the display |
|   | Text Background |
| Colour surrounding the font characters drawn on the display |
|   | Display Background |
| Colour of the background of the display |
