Component: Airplane Landing Gear (Scenarios)
| Category | Scenarios |
Airplane Landing Gear component
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
Please click here to download the component source project: FC_Comp_Source_LandingGearComponent_v002.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LandingGearComponent_v002.fcfx
Airplane Landing Gear Scenario
FrontDoorCloseSwitch
FrontDoorLocks
| FrontDoorLocks | |
| Will lock or unlock the front doors depending on the number given to the paremeter. | |
| OpenOrClose | |
| Open =1 Close=0 | |
FrontDoorOpenSwitch
FrontDoors
| FrontDoors | |
| Will allow the front doors to open. | |
| Direction | |
| Drops the door down or close them. 0 = Close 1 = Open | |
LandingGear
| LandingGear | |
| Retracts and drops the landing gear. | |
| Direction | |
| Drop the wheel down or retracts them. 0 = Retracts 1 = Drop | |
LandingGearDownSwitch
LandingGearUpSwitch
| LandingGearUpSwitch | |
| Test to see if the Landing Gear will touch the collision switch above it. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended | |
RearDoorCloseSwitch
| RearDoorCloseSwitch | |
| Test to see if the rear door will touch the collision switch by its original position. If it does, will return true. and stop movement. | |
RearDoorLocks
| RearDoorLocks | |
| Will unlock or lock the rear doors | |
| OpenOrClose | |
| Open =1 Close =0 | |
RearDoorOpenSwitch
| RearDoorOpenSwitch | |
| Test to see if the rear door will touch the collision switch by its final position. If it does, will return true. and stop movement. | |
RearDoors
| RearDoors | |
| Will allow the rear door to open | |
| Direction | |
| Drop the door down or close them. 0 = Close 1 = Open | |
| Properties |
