Component: One Wire (DS2482) (Comms: Interface)
Jump to navigationJump to search| Author | MatrixTSL |
One Wire (DS2482) component
A One Wire master transciever controlled using I2C comms. Useful for microcontroller devices where One Wire communications timings are too tight to do reliably.
Please click here to download the component source project: FC_Comp_Source_One_Wire_DS2482_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_One_Wire_DS2482_I2C.fcfx
BusReset
GetDeviceCount
|   | GetDeviceCount |
| Returns the number of devices found by the last ScanBus operation. | |
|  - BYTE | Return |
GetIDByte
|   | Initialise |
|  - VOID | Return |
MatchROM
|   | MatchROM |
| Performs a reset followed by the MatchROM code and then the 8-bit ROM code. | |
|  - BYTE | FamilyCode |
|  - BYTE | SerialNumber |
|  - VOID | Return |
ReceiveByte
|   | ReceiveByte |
| Receives a byte from the one wire bus a bit at a time | |
|  - BYTE | Return |
ScanBus
|   | ScanBus |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
|  - BYTE | Return |
SkipROM
|   | SkipROM |
| Performs a bus reset and the sends the SkipROM command byte | |
|  - VOID | Return |
TransmitByte
|   | TransmitByte |
| Transmit a byte to the one wire bus a bit at a time | |
|  - BYTE | Command |
|  - VOID | Return |
