Component: Potentiometer (Analog Input)
| Category | Analog Input |
Potentiometer component
Please click here to download the component source project: FC_Comp_Source_Potentiometer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Potentiometer.fcfx
Ev_Start
|   | Ev_Start |
| Broadcast to all components that simulation is starting | |
|  - ULONG | Return |
GetValue
|   | GetValue |
| Get the Float value, between lower and upper bounds. Used on App Developer | |
|  - FLOAT | Return |
ReadAsByte
|   | ReadAsByte |
| Read the ADC as a byte | |
|  - BYTE | Return |
ReadAsFloat
|   | ReadAsFloat |
| Reads the ADC as a direct voltage | |
|  - FLOAT | Return |
ReadAsInt
|   | ReadAsInt |
| Read the ADC at full bit depth | |
|  - INT | Return |
ReadAsVoltage
|   | ReadAsVoltage |
|  - FLOAT | Return |
SetValue
|   | SetValue |
| Sets the Float value, between lower and upper bounds. Used on App Developer | |
|  - FLOAT | Value |
|  - VOID | Return |
