Component: Solenoid Template (Mechatronics)
Revision as of 13:14, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Mechatronics
Solenoid Template component
Base component for constructing solenoids. These take a single input pin and move an actuator between two positions depending on the pin state.
Please click here to download the component source project: FC_Comp_Source_solenoid_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_solenoid_base.fcfx
SetState
SetState
Trun the solenoid on or off using a boolean value.
- BOOL State
The new state for the solenoid to take.
SetTarget
SetTarget
Choose an extermal object to move along with the solenoid's actuator
- HANDLE Object
An object to be moved by the solenoid
TurnOff
TurnOff
De-activate the solenoid
TurnOn
TurnOn
Activate the solenoid
Connection
Pin
Chip pin to connect the solenoid circuit to. NB) Solenoid cannot be moved unless there is a valid connection.
Moving part
A panel object to be moved back and forth when the solenoid is activated.
Pivot object
A position to rotate around when the solenoid type is set to 'Rotate' Not required for linear solenoids.
Type
The type of motion of the solenoid actuator.
Axis
For linear solenoids, the axis along which the actuator will move. For rotary solenoids, the axis around which it will rotate.
Distance
For linear solenoids, the distance between the 'off and 'on' states in model units. For rotary solenoids, the rotation in degrees.
Time (ms)
The time taken for the solenoid to move between the on and off positions. Used only for the purpose of System Panel animations on screen.
