Component: Analogue Temp Sensors (Environmental)
Author Medelec35
Category Environmental
Analogue Temp Sensors component
A range of the most popular temperature analogue sensors which are: AD22100, AD22103, LM135, LM235, LM335, LM34, LM35, LM60, MCP9700, MCP9701, TC1047, TMP35, TMP36, TMP37 & TSIC301. Uses a single ADC pin which will allow you to display the temperature in C or F. If your sensor is not listed, there is a Custom option. You will be able to enter the scale factor, offset voltage, Temperature Compensation, min and maximum temperatures If the temperature is outside the min and max values, then 999.9 will be displayed.
Please click here to download the component source project: FC_Comp_Source_Analogue_Temperature_Sensors.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Analogue_Temperature_Sensors.fcfx
Example Program showing how to show the temperature in Celsius and Fahrenheit and expected ADC pin voltage on an LCD. FC6 Icon.png Analogue Sensors Example
GetTempFloatC
Fc9-comp-macro.png GetTempFloatC
Value of the temperature in deg C 999.9 = temperature outside of sensor range
GetTempFloatF
Fc9-comp-macro.png GetTempFloatF
Value of the temperature in deg F 999,9 = temperature outside of sensor range
GetTempIntCX10
Fc9-comp-macro.png GetTempIntCX10
Value of integer temperature in deg C x10 E.g 22.5C will give the result of 225 This allows more contol if using integers to save memory 9999 = temperature outside of sensor range
Fc9-s16-icon.png - INT Return
GetTempIntFX10
Fc9-comp-macro.png GetTempIntFX10
Value of integer temperature in deg F x10 E.g 62.5F will give the result of 625 This allows more contol if using integers to save memory 9999 = temperature outside of sensor range
GetTempStringC
Fc9-comp-macro.png GetTempStringC
String value of integer temperature in deg C to one decimal place. E.g 22.5 999,9 = temperature outside of sensor range
GetTempStringF
Fc9-comp-macro.png GetTempStringF
String value of integer temperature in degF to one decimal place. E.g 70.2 999,9 = temperature outside of sensor range
IntValueADC
Fc9-comp-macro.png IntValueADC
The Integer ADC value of the sensor output volttage
VoltageADC
Fc9-comp-macro.png VoltageADC
Calculates what the approximate voltage should be based on Vref, Scale factor, Offset. For TSIC301, based on Max temp and Min temp only.
Fc9-type-16-icon.png Select Sensor
Select the required sensor. Custom allows you to enter parameters of an analogue sensor not covered.
Fc9-conn-icon.png ADC Properties
Fc9-type-6-icon.png Channel
Fc9-type-21-icon.png Vref (mV)
For a more accurate reading, enter the exact referance voltage.
Fc9-type-21-icon.png Total average samples
The number of ADC samples taken. The higher the number the more stable the reading.
Fc9-conn-icon.png Sensor Characteristics
Fc9-type-14-icon.png Temp compensation x10
Set value to compensate for sensor and other vairations. E.g. -10 = Set the temperature 1 degrees lower 5 = Set the temperature 0.5 degrees higher
Fc9-type-21-icon.png Scale factor (mV x100)
for a scale factor of 22mv/C or 22mV/F it's 2200. Scale factor is set for you automatically. It can only be adjusted when custom is selcted.
Fc9-type-21-icon.png Offset (mV)
Offset is set for you automatically. It can only be adjusted when custom is selcted.
Fc9-type-14-icon.png Max Temp
Max Temp the sensor can reach is set for you automatically. It can only be adjusted when custom is selcted.
Fc9-type-14-icon.png Min Temp
Fc9-type-14-icon.png Centigrade
0 for a fahrenheit sensor. 1 for a centigrade sensor. Can only be changed when custom is selected.
Fc9-type-14-icon.png Kelvin
1 for a kelvin sensor. Can only be changed when custom is selected.
