Component: Hopper (Industrial)
Category Industrial
Hopper component
A simple hopper that can be used to store produce. The hopper has component macros to set and get the current level of produce. The hopper can be initialised to be full or empty when starting. Compatible with SCADA interconnecting pipe components.
Please click here to download the component source project: FC_Comp_Source_Hopper.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Hopper.fcfx
Industrial Tanks
A simple example showing the hoppers, valves and pipes working together. Each tank automatically empties in turn.
Industrial Tanks
AdjustLevel
AdjustLevel
Allows the lelev in the hopper to be adjusted up or down.
- FLOAT Adjustment
GetLevel
GetLevel
Returns the current amount of produce in the hopper.
- FLOAT Return
IsEmpty
IsEmpty
Check to see if the hopper is currently empty. Returns 0 if not empty or 1 if empty.
- BOOL Return
IsFull
IsFull
Check to see if the hopper is currently full. Returns 0 if not full or 1 if full.
- BOOL Return
SetLevel
SetLevel
Sets the current amount of produce in the hopper.
- FLOAT Level
The amount of produce in the hopper.
Max Produce
Maximum amount of produce that can be stored in the hopper.
Default State
The initial state of the volume of produce in the hopper when the runtime starts
Plot Waveform
Allows the current level of produce in the hopper to be automatically plotted using the data recorder window.
Title
Show Title
Decides if the hopper title is shown
Title Colour
Title Label Color
Title Text
Title Label Text
Title Scale
Controls the size of the title text on the panel, default 1.2
Title Offset
Distance above component center to draw the title
Show Label
Decides if a label is shown detailing current amount of produce in the hopper
Label Colour
Sets the label colour
Label Units
Adds a unit to the end of the label
Label Decimal Points
Number of decimal points to round the label value to.
Label Scale
Sets the size of the label on the panel, default 1.0
Label Offset
Distance above component center to draw the value
Scheme
Hopper Colour
Sets the colour for the hopper
Produce Colour
Sets the colour for the produce
