Component: Injector (CAN) ()
Category
Injector (CAN) component
Comms data injector to allow CAN message identifiers to be decoded to specific message strings. Uses an external CSV file to specify the IDs and descriptive strings.
Please click here to download the component source project: FC_Comp_Source_InjectorCAN.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorCAN.fcfx
The CAN component works together with the injector component to allow you to decode a CAN message ID into a meaningful command.
Example File CAN_Example1 When a key on the keypad is pressed the CAN components transmits a CAN packet.
The CAN packet is decoded by the injector component to give us a meaningful log on the console window.
High Level CAN Data Console
Low Level CAN Data Console
Reference from CAN Injector to ID decode file, $(srcdir) refers to the current project directory.
Demo CAN ID file File:CANID.csv
GetConsoleHandle
GetConsoleHandle
- BYTE HandleIndex
Selects which console handle to obtain - 0=ID/Data 1=ID Meanings
- HANDLE Return
InitialiseInjector
InitialiseInjector
- STRING InjectorName
RxByte
RxByte
TxByte
TxByte
Puts a byte onto the comms channel. CAN packet is inserted into injector like this: ID3, ID2, ID1, ID0, D7, D6, D5, D4, D3, D2, D1, D0, \n
- BYTE DataByte
CAN Injector Settings
Circular Buffer Size
Number of bytes that can be held in the injector's circular buffer
Termination Character
Used to signify the end of a message, in the case of CAN it will end a specific identifier message
CSV ID File
Location of comma seperated ID description file. e.g. ID,Description 1,Door Open 2,Door Closed 3,Window Open 4,Window Closed 1023,System Disable 1024,System Enable
