Component: API (Interface Board) (API Slave Devices)
- 1 API (Interface Board) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ADCSample10
- 5.2 ADCSample8
- 5.3 I2CInitialise
- 5.4 I2CReceive
- 5.5 I2CRestart
- 5.6 I2CSend
- 5.7 I2CStart
- 5.8 I2CStop
- 5.9 I2CTransInit
- 5.10 I2CTransReceive
- 5.11 I2CTransSend
- 5.12 IOGetInputPin
- 5.13 IOSetOutputPin
- 5.14 Initialise
- 5.15 PWMDisable
- 5.16 PWMEnable
- 5.17 PWMSetDuty8
- 5.18 PWMSetPrescaler
- 5.19 SPIInitialise
- 5.20 SPIPrescaler
- 5.21 SPITransfer
- 5.22 SPITransferTrans
- 5.23 ServoDisable
- 5.24 ServoEnable
- 5.25 ServoSetPosition8
- 5.26 UARTBaud
- 5.27 UARTCheckRX
- 5.28 UARTInitialise
- 5.29 UARTReceive
- 5.30 UARTSend
- 5.31 WIFIGetIP
- 5.32 WIFIIsConnected
- 5.33 WIFISetSSID
- 6 Property reference
Connects to an Interface Board running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART / DAC / Servo See Instructables for open source project files.
Please click here to download the component source project: FC_Comp_Source_Interface_Board_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Interface_Board_Comp.fcfx
A board designed to allow PC access to embedded style electronic signals at 3V3 or 5V.
Includes: ADC / DAC / I2C / IO / Servo / SPI / UART
USB Firmware allows control via a USB connection. Works with a Windows PC but should also work with other USB master based devices.
WIFI Firmware allows control via a WIFI network connection. Works with any networked device including devices via the internet. WIFI connection requires the use of the UART peripheral and so this is not available for Slave functionality when using the WIFI firmware.
Board supplied with firmware as requested. Firmware can be changed using a PICkit 3 or PICkit 4 device or similar Microchip programmer.
To setup the WIFI to work with your own network you first need to power up the board using a USB connection or by applying a 5V power supply between the 5V and GND pins. Next connect to the WIFI network hosted by the board with the network name InterfaceBoard using password all in lowercase as the Password. Visit the website at page 192.168.4.1 and then enter your WIFI network details into the form provided. On clicking ok the board will store the details in none volatile memory and attempt to connect to your network and establish a local IP address. If all goes ok here then the Interface Board network should dissappear.
Refer to your router configuration page to see the IP address of the device.
If the WIFI network is not available then the board will revert back to it's setup mode allowing the network to be changed. Once network connection is available again the board will automatically reconnect.
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
Rapid Development - Virtualised SPI
A feature of the App Developer Slave interface is to use the component for rapid development.
The App Developer Slave hardware can be used to take communications from the Flowcode simulation and transfer them to a real world device allowing for easy code generation and test without having to download to a target microcontroller device.
The CS pin and SPI Prescaler are set via the properties of the Injector component.
The SPI Master component is linked to the Injector component via the Injector property.
The Injector component is linked to the App Developer Slave component via the App Developer Slave property.
Interface Board App Developer Slave SPI Demo
Rapid Development - Virtualised I2C
The I2C Master component is linked to the Injector component via the Injector property.
Interface Board App Developer Slave I2C Demo
Rapid Development - Virtualised UART
The Baud rate and optional RS485 Properties are set via the properties of the Injector component.
The UART component is linked to the Injector component via the Injector property.
Interface Board App Developer Slave UART Demo
ADCSample10
| ADCSample10 | |
| Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-5 | |
ADCSample8
| ADCSample8 | |
| Reads the voltage present on an Alanog pin as an 8-bit value range 0-255 | |
| ADCChannel | |
| Range: 0-5 | |
I2CInitialise
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
| Channel | |
| Baud | |
I2CReceive
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| Last | |
I2CRestart
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| Channel | |
I2CSend
| I2CSend | |
| Channel | |
| DataOut | |
I2CStart
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
I2CStop
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
I2CTransInit
I2CTransReceive
I2CTransSend
IOGetInputPin
| IOGetInputPin | |
| Pin | |
| Range: 0-17 | |
IOSetOutputPin
| IOSetOutputPin | |
| Pin | |
| Range: 0-17 | |
| State | |
| Range: 0-1 | |
PWMDisable
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-1 | |
PWMEnable
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-1 | |
PWMSetDuty8
| PWMSetDuty8 | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-1 | |
| Duty | |
| Range: 0-255 | |
PWMSetPrescaler
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Prescaler | |
SPIInitialise
| SPIInitialise | |
| Channel | |
SPIPrescaler
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
SPITransfer
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
SPITransferTrans
ServoDisable
| ServoDisable | |
| Disable a Servo output | |
| Channel | |
| Range: 0-5 | |
ServoEnable
| ServoEnable | |
| Enable a Servo output | |
| Channel | |
| Range: 0-5 | |
ServoSetPosition8
| ServoSetPosition8 | |
| Sets the position as an 8-bit value | |
| Channel | |
| Range: 0-1 | |
| Position | |
| Range: 0-255 | |
UARTBaud
UARTCheckRX
| UARTCheckRX | |
| Channel | |
UARTInitialise
| UARTInitialise | |
| Channel | |
UARTReceive
| UARTReceive | |
| Channel | |
UARTSend
| UARTSend | |
| Channel | |
| Data | |
WIFIGetIP
| WIFIGetIP | |
| Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active. | |
WIFIIsConnected
| WIFIIsConnected | |
| Checks to see if the WIFI is active and connected | |
WIFISetSSID
