Component: Network Communications (Comms: Networking)
Revision as of 08:59, 9 June 2025 by Wiki bot (talk | contribs)
Version 1.5
Category Comms: Networking
Network Communications component
A component designed to simplify the process of TCP/IP communications. Compatible with most of the Flowcode supported TCP/IP and WIFI components. A useful building block for creating components such as IoT and Modbus TCP.
AcceptClose
AcceptClose
Goes with the AcceptOpen function to close the new thread handle.
AcceptOpen
AcceptOpen
Required for systems where there can be multiple incoming threads Returns 1 if there is incoming comms requiring a new thread, else returns 0
Connect
Connect
Connects to an IP address as a client on the specified port. Some TCP/IP modules (RPI and ESP8266) will accept a URL instead of an IP address. Returns: 0=Fail, 1=OK
- STRING Address
IP address as a string e.g. "192.168.1.1" or URL on some TCP/IP modules
- UINT Port
Port number to connect to.
- BOOL Return
Initialises the network communications component.
Listen
Listen
Bind the socket to a port on the local host and set to listen mode. First Open a Socket on the local host Returns: 0=Fail, 1=OK
- UINT Port
Port number to listen on.
- BOOL Return
Receive
Receive
Attempts to receive up to a specified number of bytes from the active connection. Returns the number of bytes received.
- STRING Data
Data Array to store the data into.
- UINT Count
Maximum number of bytes to read
- UINT Timeout
Maximum time to wait in mS (approx)
Send
Send
Sends the specified number of bytes via the active connection. Returns the number of bytes sent, 0=Fail.
- STRING Data
Array containing the data to send
- UINT Count
Number of bytes to send from the data array
SocketClose
SocketClose
Closes the current socket connection
SocketOpen
SocketOpen
Attempts to create a socket on the local device. This must be succesful to allow TCP/IP communications with a remote destination. Returns: 0=Fail / 1=OK
- BOOL Return
LinkTo
TCP IP Channel
Allows for several parallel TCP/IP communications channels to be active at once by selecting unique TCP IP channels for each Network Comms component. Default 0.
Status
Simulation Control
Allows the user to decide what happens when simulating. Simulation DLL forces all simulated TCP/IP comms to go directly via the simulation DLL bypassing any additional components. Component simulation forces the attached component to provide the simulation and maybe other aspects such as SPI/I2C communications.
Network Interface
Some computers may have several network interfaces such as ethernet ports and wifi access. Select the correct network interface for the network you wish to connect to. Use the IP address to confirm you are connected to the right network.
IP Address
IP Address of the selected network interface.
Please click here to download the component source project: FC_Comp_Source_NetworkComms.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_NetworkComms.fcfx
