Component: Thermocouple (MCP960X) (Environmental)
| Category | Environmental |
Thermocouple (MCP960X) component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
Sim Demo
| Configures the I2C bus ready for communications. | |
ReadReference_Float
| ReadReference_Float | |
| Returns the reference (IC die) temperature from the last sample as a floating point. Use Sample first, which samples both reference & themocouple temperatures. | |
ReadReference_Int
| ReadReference_Int | |
| Returns the Reference (IC die) temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
ReadThermocouple_Float
| ReadThermocouple_Float | |
| Returns the thermocouple temperature from the last sample as a floating point value. Use Sample first, which samples both reference & themocouple temperatures. | |
ReadThermocouple_Int
| ReadThermocouple_Int | |
| Returns the thermocouple temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
Read_N_Registers
| Read_N_Registers | |
| Reads a number of sequential bytes starting from the specified register | |
| Address | |
| Data | |
| Count | |
Read_Register
| Read_Register | |
| Reads a byte from a register | |
| Address | |
Sample
Write_N_Registers
| Write_N_Registers | |
| Writes a set of data values to a sequential registers on the accelerometer | |
| Start_Reg | |
| Num_Regs | |
| Data | |
Write_Register
| Write_Register | |
| Writes a byte to a register | |
| Address | |
| Data | |
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMCP960X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMCP960X.fcfx
