Component: Dial control (Misc)
Author
Version 1.1
Category Misc
Dial control component
Dial output control
Please click here to download the component source project: FC_Comp_Source_dial.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_dial.fcfx
GetPos
GetPos
Gets the position of the pointer
- FLOAT Return
SetAngles
SetAngles
Sets the min-max angles to draw on the dial Used for setting the needle Defaults are 135 and -45
- INT Start
- INT End
SetLabel
SetLabel
Sets the label to draw in the center of the dial
- STRING Hi
- STRING Lo
Label to draw at the bottom
SetMarks
SetMarks
Decides on the presentation of the dial
- INT Marks
Number of marks on the dial
- INT Subs
Number of marks before a 'main' mark - can be zero
- BOOL ShowNumbers
True to show numbers on the dial, else false
SetPos
SetPos
Sets the position of the dial, bounded to the pre-set range
- FLOAT Position
The position of the dial in the Users specified range
- BOOL Notify
Set to true to notify owner Target of a change
SetRange
SetRange
Sets the min-max range to draw on the dial Used for setting the needle
- INT Start
- INT End
SetTarget
SetTarget
Sets the target of change messages Send 0 as the target ID to disable
- HANDLE Target
The target component to recieve the message
- ULONG MessageId
The identifier of the message to send to
