Component: SPI (CAL) (Misc)
| Version | 2.1 |
| Category | Misc |
SPI component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Serial Peripheral Interface peripheral.
Please click here to download the component source project: FC_Comp_Source_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI.fcfx
GetConsoleHandle
|   | GetConsoleHandle |
| Returns a handle to the console used by this component | |
|  - HANDLE | Return |
GetList
|   | GetList |
| returns Named property list | |
|  - STRING | Name |
|  - STRING | Return |
GetValue
|   | GetValue |
| Reads Named property Value. | |
|  - STRING | Name |
|  - STRING | Return |
Master_Byte
|   | Master_Byte |
| Sends and receives a data byte | |
|  - BYTE | DataOut |
|  - BYTE | Return |
Master_Disable_CS
|   | Master_Disable_CS |
| Outputs a high signal to the chip select pin to deselect the remote slave device. | |
|  - VOID | Return |
Master_Enable_CS
|   | Master_Enable_CS |
| Outputs a low signal to the chip select pin to select the remote slave device. | |
|  - VOID | Return |
Master_Init
|   | Master_Init |
| Initialise the Master | |
|  - BYTE | Return |
Master_Transaction
Master_Uninit
|   | Master_Uninit |
| Uninitialise the Master | |
|  - VOID | Return |
Prv_TextConsole
SetPrescaler
|   | SetPrescaler |
| Sets the prescaler value for the clock divider chain | |
|  - BYTE | Prescaler |
|  - VOID | Return |
SetValue
|   | SetValue |
| Change Named property to new Value. | |
|  - STRING | Name |
|  - STRING | Value |
|  - VOID | Return |
Slave_Init
|   | Slave_Init |
| Initialise the Slave | |
|  - VOID | Return |
Slave_RxByte
|   | Slave_RxByte |
| Returns the data received from the SPI Master | |
|  - BYTE | Return |
Slave_TxByte
|   | Slave_TxByte |
| Sets the data to be transmitted to the SPI master. | |
|  - BYTE | Data |
|  - VOID | Return |
Slave_Uninit
|   | Slave_Uninit |
| Uninitialise the Slave | |
|  - VOID | Return |
