| Author
Matrix Ltd
| Version
1.0
| Category
General Output
PWM (Internal) component
Pulse Width Modulation, a versitile way of generating a digital pulse using mark / space modulation.
Uses the capture compare peripherals onboard most Microcontrollers to generate accurate waveforms without any intervention from the processor.
Useful for generating audio, controlling the speed of motors, brightness of LED etc.
Note: To change from the PWM slider to the digital version that you can see in the image below.
Within the PWM properties, under Simulation, change Representation from Analogue to Digital.
Please click here to download the component source project: FC_Comp_Source_PWM_Output.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PWM_Output.fcfx
Here is a basic example to control the PWM duty based on an ADC reading.
PWMDemo
Digital PWM trace
Here is another basic example which ramps the PWM duty cycle up and down. If the PWM output pin is connected to a LED and series resistor then the LED will smoothly transition between on bright and off.
PWM Fader
ChangePeriod
ChangePeriod
| Sets the overall period and prescaler of the output PWM signal.
- UINT
Period
| The maximum number that will represent 100% on, PIC/AVR: 0-255 16-bit PIC: 0-65535
- INT
Prescaler
| The scaler used to divide the system clock speed down to the PWM rate.
Disable
Disable
| Disables a PWM channel and allows the default output / input state to be resumed
Enable
Enable
| Enables a PWM channel as an output overriding the default output pin state.
SetDutyCycle
SetDutyCycle
| Sets the PWM duty cycle in terms of on/off based on the current period setting. E.g. if period = 255 then duty of 128 is equal to 50% on and 50% off. 16-bit PIC users should use the 10bit duty function to access the full range.
- BYTE
Duty
| 8-bit PWM duty 0-255
SetDutyCycle10Bit
SetDutyCycle10Bit
| PIC/AVR - Sets the full scale PWM duty cycle based on the current period setting. If period = 255 then Duty of 512 is equal to 50%. 16-bit PICs have a 16-bit period range available. If period = 65535 then Duty of 32768 is equal to 50%.
- UINT
Duty
| PWM duty PIC/AVR: 0-1023 16-bit PIC: 0-65535
SetFrequency
SetFrequency
| Sets a PWM of the specifed frequency at a duty of 50% Ideal use is a frequency generator
- ULONG
Frequency
| Enter frequency in Hz
| Selects which PWM channel the component is connected to.
Alternative pin
| Allows an alternate pin to be used if available. Note that on some devices you will also have to change this setting in the device configuration.
PWM Pin
| Specifies the pin assigned to the PWM channel selected
Remap Pin
| Allows the PWM hardware pin to be reassigned to another pin
PWM Frequency
PWM Timer
| Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Period Overflow
| Allows the user to change the number of counts for the whole PWM period. Note that all PWM channels based on the same timer will share the same period overflow. PIC/AVR Range: 0 - 255 16-bit PIC Range: 0 - 65535
Prescaler
| Allows the user to change the number of program cycles per PWM cycle count. Note that all PWM channels based on the same timer will share the same prescaler.
Period (us)
| Displays the length of time to complete one PWM cycle.
Frequency (Hz)
Frequency (KHz)
| Displays the frequency of PWM cycles per second.
Calculations
Required Frequency (Hz)
| Type in your required frequency in Hz and the component will automatically calculate the best prescaler and period to acheive the frequency with the maximum possible resolution.
Calculated Frequency (Hz)
| The frequency we have ended up acheiving using the calculated period and prescaler
Calculated Period
| The suggested period setting to use to acheive the calculated frequency.
Calculated Prescaler
| The suggested prescaler setting to use to acheive the calculated frequency.
Apply To Defaults
| Applies the calculated period and prescaler settings to the PWM component default settings.
Representation
| Edits how the PWM is shown on the simulation panel.
