Component: CAN Bus BL0140 (E-blocks 2)
Revision as of 10:26, 20 October 2023 by Wiki bot (talk | contribs)
Author
Category E-blocks 2
CAN_Bus_BL0140 component
Please click here to download the component source project: FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
ChangeRate
Fc9-comp-macro.png ChangeRate
Simple attempt to alter the bus rate of the CAN. External CAN channels only,
Fc9-u8-icon.png - BYTE Rate
Rate: 0-3 where 0=125, 1=250, 2=500, 3=1000
CheckRx
Fc9-comp-macro.png CheckRx
Checks to see if any messages are available for 'Buffer' specified
Fc9-u8-icon.png - BYTE Buffer
Send buffer: 0 to 1
GetRxData
Fc9-comp-macro.png GetRxData
Returns last received message data byte at position Index. Buffer parameter is currently ignored
Fc9-u8-icon.png - BYTE Index
GetRxDataCount
Fc9-comp-macro.png GetRxDataCount
Returns last received message data length. Buffer parameter is currently ignored
GetRxIDHi
Fc9-comp-macro.png GetRxIDHi
Gets the Hi byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
Receive Buffer. Range 0-1
GetRxIDLo
Fc9-comp-macro.png GetRxIDLo
Gets the Lo byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
GetRxIDSimple
Fc9-comp-macro.png GetRxIDSimple
Gets the Rx ID as a Integer Standard ID only 0-2047.
GetRxIdent
Fc9-comp-macro.png GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png Initialise
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
ReadSwitches
Fc9-comp-macro.png ReadSwitches
Returns switch input states from the external MCP2515 device. 0 = No Switch Pressed, 1 = Switch 1 Pressed, 2 = Switch 2 Pressed, 3 = Both Pressed (External CAN only)
SendBuffer
Fc9-comp-macro.png SendBuffer
Transmits one of the transmit buffers which should have already been populated with an ID and data.
Specifies which transmit buffer to send
SetRxFilter
Fc9-comp-macro.png SetRxFilter
Allows the receive ID filter to be configured on the fly allowing different ID ranges to be received.
Fc9-u8-icon.png - BYTE Filter
Specifies which receive filter to modify. Range: 0-5
Fc9-u32-icon.png - ULONG ID
The ID filter value you wish to use
SetRxFilterID
Fc9-comp-macro.png SetRxFilterID
sets the Filter Standard mode only (for V5 compatibility only)
Specifies which filter to modify. Range: 0-5
Fc9-u8-icon.png - BYTE Hi
ID bits 3-10
Fc9-u8-icon.png - BYTE Lo
ID bits 0-2 stored in the upper 3 bits of the byte
SetRxMask
Fc9-comp-macro.png SetRxMask
Allows the receive ID mask to be configured on the fly allowing different ID ranges to be received.
Fc9-u8-icon.png - BYTE Mask
Specifies which receive mask to modify. Range: 0-1
The ID mask value you wish to use
SetRxMaskID
Fc9-comp-macro.png SetRxMaskID
set the Mask Standard ID mode only (for V5 compatibility)
ID bits 3-10
SetTxData
Fc9-comp-macro.png SetTxData
Assigns one of the outgoing transmit buffers with data ready to be sent.
Fc9-u8-icon.png - BYTE Count
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
SetTxID
Fc9-comp-macro.png SetTxID
Set the Tx CAN ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
Transmit buffer to load. Range: 0-2
ID bits 3-10 e.g. ((ID & 0x7F8) >> 3)
ID bits 0-2 stored in the upper 3 bits of the byte e.g. ((ID & 0x7) << 5)
SetTxIDSimple
Fc9-comp-macro.png SetTxIDSimple
Set the Tx CAN ID as a generic number. Standard IDs only 0-2047.
Fc9-u16-icon.png - UINT ID
The ID value you wish to use. Range: 0-2047
SetTxIdent
Fc9-comp-macro.png SetTxIdent
Set the Tx CAN ID as a generic number. Standard and extended IDs Standard 0-2047 Extended 2048-536870911
The ID or Extended ID value you wish to use. Range: 0-536870911
ShowLEDs
Fc9-comp-macro.png ShowLEDs
Set LED state (External CAN only)
Fc9-u8-icon.png - BYTE led1
Controls LED 1. Range: 0-1
Fc9-u8-icon.png - BYTE led2
Controls LED 2. Range: 0-1
Fc9-conn-icon.png SPI
Fc9-type-16-icon.png External/Internal
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Fc9-type-16-icon.png CHANNEL
SPI Channel selector
Fc9-type-19-icon.png Port
Fc9-type-5-icon.png INT
Fc9-type-5-icon.png CS (SS)
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-16-icon.png Sample Point
Data bit read sample point
Fc9-type-16-icon.png Config Delay
Fc9-conn-icon.png TX Buffer 0
Fc9-type-14-icon.png Message ID
TX Buffer 0 Message Identifier
Fc9-type-14-icon.png Length
TX Buffer 0 Number of data bytes
Fc9-type-14-icon.png D0
TX Buffer 0 Data Byte 0
Fc9-type-14-icon.png D1
TX Buffer 0 Data Byte 1
Fc9-type-14-icon.png D2
TX Buffer 0 Data Byte 2
Fc9-type-14-icon.png D3
TX Buffer 0 Data Byte 3
Fc9-type-14-icon.png D4
TX Buffer 0 Data Byte 4
Fc9-type-14-icon.png D5
TX Buffer 0 Data Byte 5
Fc9-type-14-icon.png D6
TX Buffer 0 Data Byte 6
Fc9-type-14-icon.png D7
TX Buffer 0 Data Byte 7
Fc9-conn-icon.png TX Buffer 1
TX Buffer 1 Message Identifier
TX Buffer 1 Number of data bytes
TX Buffer 1 Data Byte 0
TX Buffer 1 Data Byte 1
TX Buffer 1 Data Byte 2
TX Buffer 1 Data Byte 3
TX Buffer 1 Data Byte 4
TX Buffer 1 Data Byte 5
TX Buffer 1 Data Byte 6
TX Buffer 1 Data Byte 7
Fc9-conn-icon.png TX Buffer 2
TX Buffer 2 Message Identifier
TX Buffer 2 Number of data bytes
TX Buffer 2 Data Byte 0
TX Buffer 2 Data Byte 1
TX Buffer 2 Data Byte 2
TX Buffer 2 Data Byte 3
TX Buffer 2 Data Byte 4
TX Buffer 2 Data Byte 5
TX Buffer 2 Data Byte 6
TX Buffer 2 Data Byte 7
Fc9-conn-icon.png RX Buffer 0
Fc9-type-16-icon.png Settings
RX Buffer 0 Message Receive Mode
Fc9-conn-icon.png RX Buffer 1
RX Buffer 1 Message Receive Mode
Fc9-type-7-icon.png Simulate SPI Comms
