Component: Data Queue to Bits (DSP Inputs)
Version 1.2
Category DSP Inputs
Data Queue to Bits component
Allows data to be loaded into a buffer and then output a bit at a time into the DSP system. Useful for things like communications where data is modulated and sent out a bit at a time.
Please click here to download the component source project: FC_Comp_Source_DSP_DataToBits.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_DataToBits.fcfx
CountQueueData
CountQueueData
Returns the number of data bytes/bits remaining in the queue. The bit count includes start/stop bits.
- BOOL CountBits
0=Return Byte Count, 1=Return Bit Count
FetchNextDataBit
FetchNextDataBit
Gets the next stored bit from the data queue. If the data queue is empty then returns the default state.
QueueByte
QueueByte
Adds a single byte value to the data buffer.
- BYTE Data
QueueByteArray
QueueByteArray
Adds an array of byte values to the data buffer.
- BYTE Data
- UINT Count
QueueFloat
QueueFloat
Adds a single float value to the buffer. A 32-bit Float value occupies 4-bytes in the buffer.
- FLOAT Data
QueueFloatArray
QueueFloatArray
Adds an array of float values to the data buffer. A 32-bit Float value occupies 4-bytes in the buffer.
- FLOAT Data
- UINT Count
QueueInt
QueueInt
Adds a single integer value to the data buffer. A 16-bit integer value occupies 2-bytes in the buffer.
- UINT Data
QueueIntArray
QueueIntArray
Adds an array of integer values to the data buffer. A 16-bit integer value occupies 2-bytes in the buffer.
- UINT Data
- UINT Count
QueueLong
QueueLong
Adds a single long value to the data buffer. A 32-bit integer value occupies 4-bytes in the buffer.
- ULONG Data
QueueLongArray
QueueLongArray
Adds an array of long values to the data buffer. A 32-bit integer value occupies 4-bytes in the buffer.
- ULONG Data
- UINT Count
QueueString
QueueString
Adds an string of characters to the data buffer.
- STRING Data
DSP Buffer Properties
Buffer Size
Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
Data Queue Properties
Queue Size
Sets the number of byte elements inside the circular buffer.
Logic 1 Value
Value passed to the DSP buffer used to represent a set bit in the data queue.
Logic 0 Value
Value passed to the DSP buffer used to represent a clear bit in the data queue.
Tick Divider
Sometimes you will not want a new data bit every DSP tick. The Tick Divider property allow you to set how many DSP ticks to wait before fetching the next bit from the data buffer.
Data Order
Selects the bit order to allow the most significant or least significant bit to be sent first.
Default State
Value used when the data queue is empty
Data Format
Decides if each byte is sent out as 8-bit, 9-bit or 10-bit packets. The 9-bit and 10-bit packet types will include a start bit that is opposite to the default state. The 10-bit packet types will also include a stop bit that is the same as the default state.
