Component: GLCD (SH1106) I2C (Graphical Monochrome)
| Author | Matrix Ltd |
| Version | 1.4 |
GLCD (SH1106) I2C component
Graphical display component designed to work with the SH1106 type monochrome displays. Transfers data using a 2-wire I2C interface.
Please click here to download the component source project: FC_Comp_Source_GLCD_SH1106_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SH1106_I2C.fcfx
BPlot
Error creating thumbnail: Unable to save thumbnail to destination
BPlot |
| Sets a pixel with the current background colour at pixel location X, Y. | |
Error creating thumbnail: Unable to save thumbnail to destination - UINT
X1 |
Y1 |
Error creating thumbnail: Unable to save thumbnail to destination - VOID
Return |
ClearDisplay
ClearDisplay |
| This macro clears the display of any previous output by overwriting the entire display with the background colour. | |
Return |
DrawCircle
DrawCircle |
| Draws a circle object on the display with the center of the circle at the location X,Y | |
X |
| X Coordinate for the center of the circle | |
Y |
| Y coordinate for the center of the circle | |
Radius |
| Radius of the circle specified in pixels | |
Error creating thumbnail: Unable to save thumbnail to destination - BYTE
Transparent |
| 0=Fill inside circle using background colour / 1=Draw outer circle only | |
Solid |
| 0=Use Transparent Setting / 1=Fill with foreground colour | |
Return |
DrawEllipse
DrawEllipse |
| Draws an ellipse object on the display with the center of the ellipse at the location X,Y | |
X |
Y |
XRadius |
| Radius of the circle on the X axis specified in pixels | |
YRadius |
| Radius of the circle on the Y axis specified in pixels | |
Transparent |
Solid |
Return |
DrawLine
DrawLine |
| Draws a line with the current foreground colour from pixel location X1, Y1 to pixel location X2, Y2. | |
X1 |
Y1 |
X2 |
Y2 |
Return |
DrawRectangle
DrawRectangle |
| Draws a rectangle with the current foreground colour from pixel loaction X1, Y1 to pixel location X2, Y2 | |
X1 |
Y1 |
X2 |
Y2 |
Transparent |
| Chooses the transparency of the box - 0 = Box contains background colour, 1 = Box contains previous pixel data. | |
Solid |
| Chooses to fill the box with colour - 0 = Box contains transparency data, 1 = Box contains foreground colour. | |
Return |
Initialise |
| The Init macro must be called once to initialise the Graphical LCD display before any other Graphical LCD component macros are called. | |
Return |
| This macro prints a string of characters to the Graphical LCD. | |
Error creating thumbnail: Unable to save thumbnail to destination - STRING
Str |
| String of characters to send to the display. | |
X1 |
| X pixel coordinate to set the output string position. | |
Y1 |
| Y pixel coordinate to set the output string position. | |
Font |
| Selects which Font to use Range: 0 to Font Count | |
Transparent |
| Specifies if the background of the text is drawn - 0 = Background colour is drawn, 1 = Background colour not drawn. | |
Return |
PrintNumber |
| This macro prints a decimal number to the Graphical LCD. | |
Error creating thumbnail: Unable to save thumbnail to destination - INT
Number |
| Byte or Integer number to send to the display. | |
X |
Y |
Font |
| Range: 0 to 31 - 0=5x8, 1=10x8, 2=10x16, 3=5x16, 4-31=Extended Sizes | |
Transparent |
Return |
ReadFontStat
ReadFontStat |
| Gets a stat from the selected embedded ASCII font data. | |
Font |
| Font selection range: 0 to (NumFonts - 1) | |
Index |
| 0=SpaceWidth, 1=PixelHeight | |
Return |
ReadFontWidth
ReadFontWidth |
| Reads the number of pixel columns used in the selected font | |
Font |
Character |
| ASCII character to get the pixel width e.g. 'A' or 65 | |
Return |
SetBackgroundColour
SetBackgroundColour |
| Specifies the colour of the foreground | |
PixelColour |
| 0=White, 1=Black | |
Return |
SetDisplayOrientation
SetDisplayOrientation |
| Controls the way data is printed out on the display allowing multiple different viewing orientations. Default is 0. | |
Orientation |
| 0=Default, 1=90°CW, 2=180°CW, 3=270°CW | |
Return |
SetFontScaler
SetFontScaler |
| Allows the fonts to be scaled up by multiplying the number of pixels on the X and Y. | |
ScaleX |
| Sets the horizontal scale of the font, default 1 | |
ScaleY |
| Sets the vertical scale of the font, default 1 | |
Return |
SetForegroundColour
SetForegroundColour |
| Specifies the colour of the foreground. | |
PixelColour |
Return |
Write_Command
Write_Command |
Command |
Return |
Properties |
Dimensions |
Pixel Width |
| Width of gLCD canvas measured in pixels. | |
Pixel Height |
| Heigt of gLCD canvas measured in pixels. | |
Colour |
Monochrome |
| Specifies if the display is capable of colour or monochrome only. | |
Foreground Color |
| Specifies the initial foreground color. | |
Background Color |
| Specifies the initial background color. | |
Bit Depth |
Color Bit Depth |
| Number of bits of colour depth available on the display | |
Red Bit Depth |
| Number of bits of Red colour depth on the display | |
Green Bit Depth |
| Number of bits of Green colour depth on the display | |
Blue Bit Depth |
| Number of bits of Blue colour depth on the display | |
Connections |
I2C Address Bit |
| I2C Address Bit - Bit 0 of the address and adjustable by the user. | |
Channel |
| Channel selection | |
Baud Select |
| Baud rate option selector | |
Baud Rate |
| Baud rate to be used | |
Stop Delay |
| On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not a 10ms delay between an I2C stop event and the next I2C start event. Most modern microcontrollers will not have a problem so this property can be disabled to speed up the I2C communications. | |
SDA |
| Pin used for SDA (data signal) | |
SCL |
| Pin used for SCL (clock signal) | |
Reset |
| Display reset pin | |
Fonts |
Font Count |
| Specifies the number of fonts available to use on the display. | |
Font 0 |
Font |
| Font picker to decide which font to use on your display. | |
Character Spacing |
| Sets the number of blank pixels between each character when printing text. Default 1. | |
Space Width |
| Sets the number of horizontal pixels used to represent a space character. | |
Simulation |
Component Label |
Component Label Scale |
| The label scale can be change if the amout of text is too wide for the display | |
Physical Orientation |
| Rotates the simulated canvas to match the orientation of real world hardware. | |
Simulate Comms |
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component. | |
