Component: GLCD Bitmap Drawer FAT (Graphical Library)
| Version | 2.2 |
GLCD Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
Here is an example that will scan for bitmap files in the root of the SD card and display them on a graphical display.
The zip file contains the Flowcode project as well as some example bitmap image files taken from Pixabay.
Place the bitmap files on the root of the SD card for the embedded hardware to work.
Display_BMP
Display_BMP_Fast
GetHeight
| GetHeight | |
| Returns the height of the loaded bitmap file in pixels. | |
| Filename | |
| The filename of the bitmap we want to measure | |
GetWidth
| GetWidth | |
| Returns the width of the loaded bitmap file in pixels. | |
| Filename | |
SetTransparentColour
| SetTransparentColour | |
| Sets the transparency colour, the colour that is not drawn when transparency is enabled. | |
| R | |
| G | |
| B | |
| Properties | |
| GLCD LinkTo | |
| File LinkTo | |
| ColourDisplay | |
| Automatically detects if the graphical LCD object is colour or monochrome | |
Please click here to download the component source project: FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
